Bench Grinder
Daniel04/12/2016 17:48:40
338 forum posts
48 photos
Hello Everyone,
I recently purchased a bench grinder.
The type that has a grinding wheel on the right hand side and a wire brush on the left.
On each safety cover is a sticker saying not to install a grinding wheel on the wire brush end.
Can anyone enlighten me as to why
All the best,
Daniel
Breva04/12/2016 18:35:31
91 forum posts
7 photos
Hi Daniel,
It would help if you posted additional info and maybe a photo.
Physical size, wheel size, motor output and the type of mounting on the brush side etc, would help contributors on the forum to advise you.
Rik Shaw04/12/2016 18:38:57
1494 forum posts
403 photos
A stab in the dark. On my grinders the RH wheel is secured by a RH thread and the left hand by a LH thread. I am guessing that your grinder is RH thread at both ends in which case a wheel fitted on the LH side, it being heavier than a brush, is likely to work loose - ouch! .........Rik
Edited By Rik Shaw on 04/12/2016 18:41:01
Robbo04/12/2016 19:32:27
1504 forum posts
142 photos
When I read your problem I came to the same conclusion as Rik - both ends have the same handed nut, so if a wheel is fitted instead of a brush the nut may unscrew.
Daniel05/12/2016 07:43:41
338 forum posts
48 photos
Hello folks,
Here are some photos of the article in question . . .
Daniel05/12/2016 07:48:06
338 forum posts
48 photos
I was also thinking that it would be to do with left and right hand threads.
But, then, I don't know if being hit by an unscrewed wire brush, flying at warp #10, would be any better than a grinding wheel dont know
I did wonder if there was any other reason.
All the best,
Daniel
Sandgrounder05/12/2016 08:04:52
256 forum posts
6 photos
Could the wire brush side be threaded M14 to take screw on brushes? If so this wouldn't be suitable to mount a grinding wheel.
Mike E.05/12/2016 08:08:03
217 forum posts
24 photos
Have you removed the guard and put a spanner on the nut to find out ?
Daniel06/12/2016 14:54:26
338 forum posts
48 photos
Posted by Robbo on 04/12/2016 19:32:27:
But Robbo,
Would not the same risk apply to a brush ?
John Shepherd06/12/2016 15:49:17
222 forum posts
7 photos
Daniel
Have you actually checked the threads to see if they are R or L handed?
Another reason for the instructions stating that a grinding wheel should not be fitted is perhaps the lack of large dished washers. The brush mounting may not need these because of its metal hub but the grinding wheel needs them to spread the load.
