Dan Carter | 17/11/2016 21:38:25 |
81 forum posts 8 photos | Hi, Is there a specific name for this type of scissor jack: even better, is anyone aware of how to work out the possible pivot points without me having to dust off my rusty geometry ? The appeal is it having no need for a sliding joint as in a normal scissor lift Thanks, Dan |
Ady1 | 17/11/2016 21:47:36 |
![]() 6137 forum posts 893 photos | On a well known site they are called a lift table |
Cyril Bonnett | 17/11/2016 21:50:13 |
250 forum posts 1 photos | Hi A quick search gave the following Industrial Scissor Lift Table or a home built one. Cyril Edited By Cyril Bonnett on 17/11/2016 21:59:35 |
Dan Carter | 17/11/2016 21:53:03 |
81 forum posts 8 photos | Cyril - that is where I found the image in the first place Ady - a normal lift table doesn't have the extra/different linkage which gets rid of the need for a sliding joint, that's the bit I'm interested in |
Old School | 17/11/2016 22:01:48 |
426 forum posts 40 photos | Surely you can scale it from the picture and then draw it up to check that you got it right. |
Cyril Bonnett | 17/11/2016 22:18:57 |
250 forum posts 1 photos | The second link I posted above has a download for solidwork files |
Dan Carter | 17/11/2016 22:22:01 |
81 forum posts 8 photos | Cyril, Sorry, only read the email update which didn't include the second link - that is extremely helpful (or at least will be once I remember how to use fusion 360 to import the solidworks model) Old School - would have done if necessary, but the picture is of a decorative item, no way of knowing if it even works as shown Thanks, Dan |
norman valentine | 17/11/2016 22:30:21 |
280 forum posts 40 photos | Make a quick model out of mecano, if you don't have mecano cut some strips of cardboard. |
Dan Carter | 17/11/2016 22:38:59 |
81 forum posts 8 photos | Norman, Already did (lego, not meccano). The length and position of the short linkage affect whether the top moves vertically only or also horizontally. Am attempting to look at the model linked by Cyril to see whether it is an exact solution or not. |
JA | 17/11/2016 22:58:29 |
![]() 1605 forum posts 83 photos | Except for the screw jack each pivot is the corner of a four sided link system. These are mechanism and are free to move in the vertical plane. The screw jack holds everything together because it is part of two (although only one is actually required) three link systems. A three link system is locked and is not a mechanism. I hope this makes sense. The lift is not far removed, mechanically, for scaffolding. Unless there is a diagonal scaffold pipe in each plane the structure is very likely to collapse. It is quite neat, though. Better than my scissors type bike work bench. JA Edited By JA on 17/11/2016 22:59:22 |
Michael Gilligan | 17/11/2016 23:11:34 |
![]() 23121 forum posts 1360 photos | Dan, No promises, but I think you will find this of interest: **LINK** https://archive.org/details/howtodrawastrai01kempgoog MichaelG. |
duncan webster | 17/11/2016 23:31:22 |
5307 forum posts 83 photos | The name ought to be 'over complicated'. The sliding joints in my scissor lift are very simple, little wheels running inside folded channel. I have 4 lever bits and a cheap hydraulic jack, the one in photo has 12 and a bespoke leadscrew arrangement. Nuff Sed? |
Dan Carter | 17/11/2016 23:52:08 |
81 forum posts 8 photos | True, but it has more in common with a double scissor lift than a single as regards height vs length (which matters for my purpose), which would double your lever bits. In my case the bespoke leadscrew would be replaced by the guts of an electric scissor jack which I already have, so not quite as pointlessly overcomplicated as it looks |
Michael Gilligan | 18/11/2016 00:14:44 |
![]() 23121 forum posts 1360 photos | Posted by duncan webster on 17/11/2016 23:31:22:
The name ought to be 'over complicated'. The sliding joints in my scissor lift are very simple, little wheels running inside folded channel. I have 4 lever bits and a cheap hydraulic jack, the one in photo has 12 and a bespoke leadscrew arrangement. Nuff Sed? . Sorry, Duncan ... I have to disagree The 'Lab Jacks' that I bought for close-up photography are crude and precarious compared with what Dan shows ... [because; as the elevation increases, the support becomes narrower ... which is exactly what is not wanted]. MichaelG. . https://en.m.wikipedia.org/wiki/Laboratory_scissor_jack Edited By Michael Gilligan on 18/11/2016 00:18:24 |
Paul Lousick | 18/11/2016 07:04:07 |
2276 forum posts 801 photos | Dan, What is the load capacity of your lift table ? I can open your Solidworks model but some on this forum may not. Can you post a drawing with dimensions for them ? Paul. Edited By Paul Lousick on 18/11/2016 07:06:31 |
Ady1 | 18/11/2016 07:40:24 |
![]() 6137 forum posts 893 photos | I presume that what makes this do it's job differently is the parallelogram within the structure? It puts me in mind of that screwcutting attachment which the French chap posted a while back To my mind it looks like the top left hand side has no real support compared to the right hand side, the cross member goes waaay across to the far right before it has a load bearing point Edited By Ady1 on 18/11/2016 07:54:34 |
Michael Gilligan | 18/11/2016 08:34:14 |
![]() 23121 forum posts 1360 photos | Posted by Ady1 on 18/11/2016 07:40:24:
To my mind it looks like the top left hand side has no real support compared to the right hand side, the cross member goes waaay across to the far right before it has a load bearing point . Enlighten me please, Ady I'm barely awake, but I can't see it as anything other than symmetrical. MichaelG . 'it' being the linkage [excluding the screw]. Edited By Michael Gilligan on 18/11/2016 08:49:04 |
Bazyle | 18/11/2016 08:57:27 |
![]() 6956 forum posts 229 photos | I think he means the short arm appears to give support to the RHS. It is perfectly possible to add a similar parallelogram to the LHS. The question we all want answered is how you decide on the length of the short arm for optimum performance without having to put in any thought effort into 'O-level' geometry. |
Dan Carter | 18/11/2016 09:59:52 |
81 forum posts 8 photos | Paul, it is not my table, the link was an example found by Cyril. In the model, the distance between hole centres for the long piece is 20", the short distance between end hole and attachment point of the strut is 7.5" and the distance between hole centres on the strut is 7.492" (??) However, having tried that ratio in lego, it doesn't work as I expected, the top still moves off to one side as it goes up. Possibly this is inevitable, may have to actually read Michael G's link (thanks for that) Bazyle - I think a second parallelogram won't work unless the movement is completely vertical, which it doesn't appear to be in the example. Looking like avoiding thought may be impossible (probably would have been quicker in the first place |
Dan Carter | 18/11/2016 10:20:56 |
81 forum posts 8 photos | Oops, schoolboy error, used 16 and 6 hole pieced rather than 17 and 7. Works perfectly with ratio as above |
