Z Lock for CMD10
Iain Downs17/10/2016 07:49:13
976 forum posts
805 photos
Has anyone made one of these?
The problem is that the cutter can be pushed upwards when milling unless you hold on tight to the Z (spindle) wheel. this doesn't happen all the time, so I don't grab on all the time. So the gentle rise in height is usually unnoticed.
The thoughts I've had for this is to drill and tap into the side of the Z axis gear bit and (somehow) put a clutch in.
I've not taken this apart yet to see what the dimensions look like, but there doesn't appear to be much metal so I could end up with an external clutch type thing bolted to the Z winder assembly.
However, if anyone's actually done this it will save me a whole swathe of my usual mistakes...
Iain
JasonB17/10/2016 07:55:53
There should be a bristol lever in one of the holes where the column gib screws are, this will lock the head. The quill is locked by the allen screw at the front which closes up the split.
Frances IoM17/10/2016 08:23:00
1395 forum posts
30 photos
I think it was in another competitor mag there was an article by Meek showing a simple mod to the large allen screw to ease locking of the quill - however the head is locked on the column by that single small screw working against the gib strip (and all too easy to forget to tighten until making the first cut!)- difficult to see any easy improvement here without serious butchery
Lars-G Kjellander17/10/2016 11:12:46
9 forum posts
4 photos
If you look at the pictures on Chronos or just Google "Clarke CMD10" you can see a looking lever on the left hand side of the head, if you don't have that lever maybe you install one.
Lars-G.
Iain Downs17/10/2016 20:54:17
976 forum posts
805 photos
I can lock the head on the Z gib strip - and do every time I mill - I learned that one early on1
There's an alan key on the right of the head which tightens the quill. As far as I can see (and I think confirmed in something I read somewhere), this is about stiffening the quill not about locking it in place.
The mod I think is being referenced is this http://mikesworkshop.weebly.com/mill-quill-lock-lever.html
I've tried tightening this and it has little effect with any reasonably amount of force - hence MIke's long lever. I don't think that this is what the hex key is for - as I said for stiffening the quill not locking it.
Iain
Frances IoM17/10/2016 21:52:19
1395 forum posts
30 photos
Meek's scheme was I recall a little different from Mike Cox's but basically same idea.
I suspect some problems arise in the mechanism of the fine adjustment as I think it allows some slippage.
Found Meek's mod it was originally on this board but Meek removed all his posting after some disagreement with another poster - he added a thrust race to ease movement + belleville washer to lock in place the quill lock lever
Edited By Frances IoM on 17/10/2016 21:57:39
Edited By Frances IoM on 17/10/2016 21:58:16
