Roger Hart | 23/08/2016 06:53:16 |
157 forum posts 31 photos | Recently used some mouldable plastic - where you tip granules into hot water and get a mass of clear plastic. Useful stuff but I found hard to manage. Are there any easier ways to use this than attempting to handle a hot, incredibly sticky mass. I did my job OK but found avoiding blowholes and water pockets a bit of a problem. Even getting the stuff off swmbo's saucepan and ladle was a problem.
David Colwill | 23/08/2016 08:54:36 |
782 forum posts 40 photos | Search for Formcard. There was a post on here about it not long ago (thanks Fizzy),that's how I know about it. David. |
Douglas Johnston | 23/08/2016 09:07:46 |
![]() 814 forum posts 36 photos | You don't need to use hot water, I have found a hair dryer works well but you have to contain the granules or they blow all over the place until they start to melt and stick together. Doug |
MW | 23/08/2016 09:21:01 |
![]() 2052 forum posts 56 photos | Why not take this a step further and isolate the water and plastic from each other? boil a saucepan and place a glass bowl over it, let the steam heat the bowl and let your granules melt into that instead? Buy a cheap pyrex dish from wilkos or wherever and keep it for the granules. Michael W Edited By Michael Walters on 23/08/2016 09:22:01 |
Michael Gilligan | 23/08/2016 09:26:48 |
![]() 23121 forum posts 1360 photos | I think you are right track, Michael ... Re-inventing the traditional wood-workers' Glue Pot. MichaelG. |
Roger Hart | 25/08/2016 08:54:32 |
157 forum posts 31 photos | Thanks for the replies all. I think I was heating up too much. Instructions said boiling water which is probably a bit too hot, as the stuff cools down it gets more tractable and less sticky. Other instructions say 60 degrees C which looks more sensible. I'll know next time.... |
Georgineer | 25/08/2016 09:52:39 |
652 forum posts 33 photos | You've got the answer! It works well at 60*C but if you go much hotter it actually melts and acts like hot melt glue. There is a lower temperature version available as well - in one of my jobs we used it to make personalised pencil grips and the like for disabled children. I've never used it for any precision jobs though. George |
Ady1 | 25/08/2016 15:19:31 |
![]() 6137 forum posts 893 photos | I always clean out and hang onto those microwave food dishes because they are fine up to boiling point and can be used for any guffy jobs which crop up |
