Coventry die head question
hth18/08/2016 08:13:17
93 forum posts
22 photos
I recently got hold of a Coventry die head , model CHS , I think it is the 1" version.
Do the actual dies change over from one size die head to the next size die head ? Or do you need a set of dies that are dedicated for each sized head ?
Thanks Mike
Emgee18/08/2016 08:21:27
2610 forum posts
312 photos
Hi Mike, dies are sized according to head size so are all different.
Emgee
John Stevenson18/08/2016 08:21:28
5068 forum posts
Dies for each size head.
hth18/08/2016 08:29:51
93 forum posts
22 photos
OK thanks .. seems like I need to look around for some dies !
hth18/08/2016 08:34:43
93 forum posts
22 photos
Forgot to add. The Coventry die head manual is available for free download here
http://pounceatron.dreamhosters.com/docs/index.html
Andrew Johnston18/08/2016 08:40:05
7061 forum posts
719 photos
Here's a guide I did earlier:
hth18/08/2016 09:29:37
93 forum posts
22 photos
Thanks Andrew
I think there are other brands of dies that will fit the Coventry die heads , these brands are clones or copies of the original brand . Sutton , a tool company here in Australia , is one such brand. Must be many more out there.
hth18/08/2016 09:36:51
93 forum posts
22 photos
My only set of dies
Andrew Johnston18/08/2016 09:46:17
7061 forum posts
719 photos
I'm pretty sure that Alfred Herbert no longer make Coventry dies, so all new die sets will be clones. I've bought new sets in the last year or two, which must be clones, and they work fine. Even in the heyday of Coventry dieheads there were alternative manufacturers. I've got some sets made by Robertson of Bedford, probably made in the 1960s looking at the style of the packaging.
Andrew Johnston18/08/2016 09:50:10
7061 forum posts
719 photos
Posted by hth on 18/08/2016 09:36:51:
My only set of dies
The leftmost die seems to be missing its cutting teeth?
hth18/08/2016 09:54:28
93 forum posts
22 photos
Posted by Andrew Johnston on 18/08/2016 09:50:10:
My only set of dies
Maybe the larger thread sizes are made that way ?
The die head is currently manufactured in India and sold on EBAY
http://www.ebay.com.au/itm/1-2-Coventry-Die-Head-with-4-sets-of-HSS-Chasers-/191881687371?hash=item2cad0a314b:g:2IAAAOSwn8FXRqFg
hth18/08/2016 09:59:51
93 forum posts
22 photos
The manual explains that the teeth only guide the dies , they behave like a nut, the actual cutting is done by the angled section before the teeth .
Andrew Johnston18/08/2016 11:00:18
7061 forum posts
719 photos
Posted by hth on 18/08/2016 09:59:51:
Really? Think about it! If none of the teeth cut how is the thread formed. If you look at a die end on, at the teeth, you will note that the teeth are not parallel to the axis of work rotation but angled. It is true that the teeth at the rear of the die are in front of the rotation axis and do indeed act as a guide pulling the diehead forward and eventually opening it when a stop is reached. The cutting is done by the partial teeth on the throat (angled section) and the first full depth tooth to give the full thread form.
Muzzer18/08/2016 11:53:25
2904 forum posts
448 photos
The first one has lost a couple of teeth. It's not supposed to look like that!
hth18/08/2016 12:13:12
93 forum posts
22 photos
manual2.jpgWhat the book says , the teeth guide the die , they don't cut
hth18/08/2016 12:16:28
93 forum posts
22 photos
Posted by Muzzer on 18/08/2016 11:53:25:
it was absolutely made like that !
Muzzer18/08/2016 12:21:56
2904 forum posts
448 photos
If you say so. Did he charge you extra for it?
Phil P18/08/2016 13:10:30
851 forum posts
206 photos
It was absolutely NOT made like that from new. It has been made like that by someone after they have damaged the teeth. It is not uncommon to see this sort of thing on second hand dies. I have drawers full of them.
The book also says that the cutting is done on the the throat AND THE FIRST FULL TOOTH as already explained by someone else.
Phil
JasonB18/08/2016 13:20:24
Its lucky they are 1" Whit chasers, any smaller and the work head and or head would get pushed to one side as the other three chasers try to do the work resulting in a wonky thread.
hth18/08/2016 13:45:40
93 forum posts
22 photos
The cutting edge of the dies, is defined by the throat and the first tooth flank .. look at the line on the diagram , it explains it clearly . The text was written by the manufacturers themselves ...what more can I say . You guys cannot understand plain English ..
