Martin Newbold | 17/08/2016 21:35:48 |
415 forum posts 240 photos | can someone tell me the answer to this please the widle of a ML10 bed Cheers martin |
John Stevenson | 17/08/2016 21:57:48 |
![]() 5068 forum posts 3 photos | |
DAVID POWELL 4 | 04/09/2016 13:18:24 |
26 forum posts | Mine's 3 inches |
Michael Gilligan | 04/09/2016 13:29:32 |
![]() 23121 forum posts 1360 photos | Posted by DAVID POWELL 4 on 04/09/2016 13:18:24:
Mine's 3 inches . That's bigger than John's Edited By Michael Gilligan on 04/09/2016 13:33:40 |
Martin Newbold | 08/10/2016 18:45:05 |
415 forum posts 240 photos | Thanks a bit late am working on a new project to convert ML10 tail stock to Drummond 3.5" bed. This is the first idea i come up with to cut down the ML10 saddle to bolt onto the Dummond Saddle kike the old one did making a mating surface for the new MT2 tailstock.
Here i s what i started with
Here is the bottom part Here is it cut down on image software
Cheers MN
Edited By Martin Newbold on 08/10/2016 18:48:36 Edited By Martin Newbold on 08/10/2016 19:07:51 |
Martin Newbold | 08/10/2016 18:58:38 |
415 forum posts 240 photos | Here is what its going onto |
Martin Newbold | 08/10/2016 18:59:33 |
415 forum posts 240 photos | I am hoping at least one of the screw holes will line up. |
Martin Newbold | 08/10/2016 19:07:03 |
415 forum posts 240 photos | Still working on it
Edited By Martin Newbold on 08/10/2016 19:08:42 |
Martin Newbold | 09/10/2016 16:42:34 |
Difference from Drummond tailstock saddle to center calculation Chuck Jaw height: 0.5845” Tail Centre Dia: 0.1135” Chuck Hole ½ Dia: .039/2” Total .7175"
First cut will be .08” leaving difference from block to correct height .0825" to remove if all goes well. Does this seem right? |
Martin Newbold | 10/10/2016 20:10:03 |
415 forum posts 240 photos | Some cutting down today much more to cut around 5mm to get centres same as mt1 tailpiece. Intend to take some from top and some from bottom.
Martin Newbold | 10/10/2016 20:11:13 |
415 forum posts 240 photos | Here is first try much more to cut down
Martin Newbold | 17/10/2016 16:08:05 |
First try still needs adjustment |
Martin Newbold | 17/10/2016 16:56:50 |
415 forum posts 240 photos | |
Martin Newbold | 18/10/2016 13:25:58 |
415 forum posts 240 photos | Did a bit more to this got horizontal in the ball park and just vertical is out now . Will remove 1mm and see again
MN |
Steven Greenhough | 18/10/2016 13:35:46 |
144 forum posts 54 photos | A bit late to the party but... It might be worth using a center in the spindle nose rather than a chuck? Might be that bit more accurate? |
Martin Newbold | 18/10/2016 13:50:15 |
415 forum posts 240 photos | Here is the reverse showing the ML10 interface with the old Drummond saddle which was under existing tail piece.Provision has been made to retrofit the MT1 tail piece should it ever need to be. Stil have approx 2mm to remove from top was able to remove approx 3mm from bottom. Am going to take it slow here so i can get it as tight as possible 1mm at a time. Regards
MN
Martin Newbold | 18/10/2016 13:54:37 |
415 forum posts 240 photos | Posted by Steven Greenhough on 18/10/2016 13:35:46:
A bit late to the party but... It might be worth using a center in the spindle nose rather than a chuck? Might be that bit more accurate? Yep Steven , thanks for the tip . I am still considering how to get it dead accurate . I need a 5/8 16 MT2 for my chuck to get the big chuck on it to hold something other than what I have . I have about 2 mm to remove approx so am going to take another 1 mm before I get into working out how to get it exact any ideas would be really helpful. Wont do this until next week.
MN |
Martin Newbold | 18/10/2016 14:10:19 |
415 forum posts 240 photos | Here is a ruler behind them in focus on the ruler then on tips
MadMike | 18/10/2016 14:22:43 |
265 forum posts 4 photos | All very interesting, but are we not missing the obvious here. The centre height of an ML10 is a known dimension. So why are you messing about trying to match a centre to the centre of a set of chuck jaws, or to another centre mounted in the headstock or a chuck? Why do you not simply assemble your tailstock, then measure the position of the centre and simply machine the base, however constructed to match the known ML10 centre height? It seems so straightforward to me, or am I missing something here? It almost feels like you are all trying to re-invent the wheel to me.
MadMike | 18/10/2016 14:26:12 |
265 forum posts 4 photos | I have just looked at the photos again. Is it me? You don't even have a complete centre in the tailstock, so how do you hope to match up the tips of the 2 centres when of them is not actually available to line up? |
