Member postings for DAVID POWELL 4
Here is a list of all the postings DAVID POWELL 4 has made in our forums. Click on a thread name to jump to the thread.
Thread: what width bed is an ml10 please
04/09/2016 13:18:24
Mine's 3 inches
Thread: Ahhhhh!!!! Trying to cut thread with die
19/08/2013 20:51:54
I had exactly the same problem with an M8 die (HSS) although other sizes from the same source work OK. Is it permitted for contributors to say where they buy quality taps and dies from?
Thread: Silver soldering
21/12/2012 15:05:50
I use oxy with MAP gas obtained from CWB a plumbing wholesalers in Caldicot Gwent.
The heat is almost equivalent to Oxy/acetylene and there's a range of very small (jewellers type) to very big nozzles available. Advatage is no rental costs on the bottles.
The guy who owns the place tells me plumbers who work with air conditioning love it because the gasses last a long time (compared to what was available previously).
Works really well on a 3.5" boiler.
Thread: Help required
18/11/2012 12:43:24
Dave, had exactly the same problem when making a 3'5 inch boiler for Juliet.>>
Practicing on 6 " strips of copper with the yellow gas bottle from B and Q worked a treat. BUT when using it on the boiler the heat would quickly dissipate and there was no way I could get the temp up.>>
Tried those small gas bottles from Cup alloys, no good. Spoke to 2 of the professional boiler makers who attend the shows and they both said the same thing. They blast the boiler with a big sievert then dive in with oxy/acetylene. Now the oxy set up is very expensive for the casual user but I found an alternative which is Mapp gas and oxygen from CWB's in Caldicot, near lace w:st="on">Newportlace>. Once you buy the setup circa £250 you simply pay to fill/replace the bottles about £15 each. No rental costs.>>
Using this setup and the biggest nozzle I now blast the boiler with the Sievert and dive in with the Mapp/oxy. So far it works fine. Bigger boiler may be more problematic and I am thinking of building a 'proper' grate and possibly have a gas ring(s) underneath to give a constant heat supply. Anybody got any thoughts on that?>>
Thread: Choice of Model
28/07/2012 20:10:01
When building Juliet 3.5 gauge loco the boiler was made from flat copper (available up to 10 gauge pretty easily). By luck chance or coincidence my dad came across a council workman cutting down trees. Managed to get a suitable branch which was then turned to the right diameter. Copper was then annealed and bit by bit 'turned around the branch. We held it in place using large jubilee clips. It didn't take long before it was wrapped nicely around the branch. Then drilled and riveted and then silver soldered. Worked OK this was the first time we had made a boiler.
Thread: bcd mill - stuck key
26/02/2012 19:14:30
With reference to the comments about the die, does a die cut both ways?
If not is there a correct 'way round 'to use the die. I was looking at this only a few days ago and the die seems to have the same 'start' both sides.
Thread: Brazing copper
14/02/2012 08:19:13
Thanks John Baguley, answer is spot on and I shall follow your recommendation. Nigel Jones 2 too (sounds wrong but is grammatically correct?) has a very useful idea so thanks for that.
MGJ makes the point about dezincification. I was aware of this which was another reason why I posed the original question as this loco is an LBSC, a guru amongst model makers. Did he get it wrong? Was dezincifiction known in his time?
As for the semantics, I think Dusty has a point. The trouble is whose definition do we follow. Brazing is defined as ‘solder with an alloy of brass or zinc’ so if I use a ‘silver solder rod’ is that brazing? But there again isn’t brazing a French word and translated means soldering. So silver soldering and silver brazing means the same thing?
Anyway I need to Hoover the shed, no, I’m going to Electrolux it, on second thoughts I’ll just vacuum it.
Thread: Silver silvering and heat
13/02/2012 20:18:19
When starting the boiler of the Jukliet loco I tried various sources of heat withour success. Two proffesional boiler makers told me they use acetylene.
This is very expensive for the occasional user but then I found a source which supplied me with Map/Pro gas and a large (about 2 foot tall) oxy bottle. The kit comes with everything including a trolley but you need to buy a No 28 nozzle as well as the ones supplied are too small
Now no problems silver soldering the boiler.
The source is a plumbing wholesaler http://www.cwbwholesale.com/
Tel: +44 (0)1291 431373
They are based at Caldicot, Gwent a stones throw from the Severn Bridge.
13/02/2012 19:49:12
Thanks for the advice on the books.......Will be collecting Tubal Cains' book from the library tomorrow.
The boiler is 80% complete all silver soldered as per instructions. However there are 2 copper pipes that need connecting to a 'made bend' which is quite acute, hence the need to make it I guess.
Here the instructions and the plans show them as being brazed together not silver soldered. As this design is about 60 years old perhaps using today's silver solder may be OK (has it changed in 60 years).
So I was just wondering how brazing copper is achieved. Clean the parts OK, apply flux....what flux? then heat up and use a rod of some description to bond the 2 parts together.
So what flux and what rod?
Would silver soldering would be a more than acceptable solution?
Thread: ME nuts and bolts
12/02/2012 22:21:09
Peter,
I understand your question perfectly and one might wonder why these threads were invented. Guess they have lots of threads per inch for better fixing?
As far as I know nuts and bolts in ME threads has never been available commercialy.
So you can if you wish spend a great deal of time generating expensive swarf
Pesonaly I use BA for the smaller sizes and metric for the larger. 6mm is about the same as 0BA. BUT Jason has a point with steam fittings. If you buy them they come with ME threads, so you will have to buy at least one ME tap to fix them to the boiler.
Hope this helps
12/02/2012 22:09:12
I am making the boiler for the Juliet loco. It requires some of the copper pipes to be brazed.
How do you braze copper pipes?
Thread: Silver solder or copper rod?
11/11/2011 08:29:13
Recently when buying silver solder from a local supplier he asked what I was going to use it for. I told him I ws making my first copper boiler for a locomotive. He said that if I was soldering copper to copper I could use a copper rod. A great deal cheaper and no flux needed. He gave me some rods (free) to try. He also added that if I were to solder copper to say phospher bronze I could still use these rods but use flux.
I was wondering if anyone had any experience of using these rods in boiler making and had any comments on their use. I know that airconditioning installers use them for joining copper pipes.
Thread: Milling from a sheet
08/11/2011 17:13:07
Would anyone consider using a magnetic chuck?
Can you saw it? Good excercise as well.
Thread: Books for model engineers
08/11/2011 15:34:38
We are saddened to report the death on Friday 21st October 2011 of
Dr George Daniels CBE, MBE, FBHI, widely regarded as the greatest watchmaker of his time.
Follow the link for more details.
Thread: Wheel cutting
08/11/2011 15:18:29
No South Wales, sorry.
Thread: Reamer suppler
08/11/2011 07:54:16
Anyone ever used adjustable reamers. Thought that they may be able to compensate for any wear that occurred?
08/11/2011 07:32:30
Niloch
You are absolutely right. Been giving this some thought since last post. I've been 'hung up' on determining the diameter of the blank, but it's the correct DP or module cutter that needs to be determined first, then the size of the blank can be calculated. Chapter 3 of Ivan Law's book on gear cutting explained this to me.
It is most likely that any clock or machine I ever make will be to a set of plans where all the information is given. (although it is always worth checking as even in this forum at least 2 respondents contradicted Mr Wilding's calculations).
So thank you all for your help and the many useful links that have been supplied.
QED
07/11/2011 22:02:12
Thanks blowlamp........I alreay have. What's a 'leaf'
07/11/2011 21:46:03
Nicol
It was your original thread that started me off, assuming you are the same Nicol.
Anyway take me out of my grief.
How did you calculate the diameter of the blank you used for your 290 tooth wheel?
What cutter did you use?
Why did you choose that cutter?
06/11/2011 11:42:37
Thanks for all the help......sent for Marshalls book and down loaded HPC's catalogue. The Casio tool looks too heavy for me..........unless I enrol in a night school HMMMMM
DAve
