super glue
roy entwistle14/08/2016 21:25:56
1716 forum posts
Whilst refixing the trim on his car my neighbour has had a drip of super glue down his door Any ideas on how to remove please ?
Roy
ps I think the paint could be silver metalic
Edited By roy entwistle on 14/08/2016 21:35:10
Steven Vine14/08/2016 21:38:46
340 forum posts
30 photos
A video from a detailer on you tube recommends nail polish remover. The acetone goes to work on the glue.
Steve
Bob Stevenson14/08/2016 22:06:17
579 forum posts
7 photos
Before you use acetone on metalic paint do a test somewhere out of sight,.....under the wing of under a scuttle etc., to be certain that the acetone does NOT go for either the paint sirface or any laqueur that has be put over the top.
stan pearson 114/08/2016 22:07:22
135 forum posts
Roy
Nail Varnish remover might work but make sure the car is painted in 2pack because otherwise the acetone will remove the paint .
Stan
speelwerk14/08/2016 22:16:29
464 forum posts
I would first scrape it down with a scalpel as far as you dare. Niko.
Andrew Entwistle14/08/2016 22:35:27
120 forum posts
218 photos
Toolstation sell a superglue solvent which is more benign than acetone:
Andrew.
mark smith 2015/08/2016 00:01:55
682 forum posts
337 photos
If its been waxed will it not just peel off?smiley
Speedy Builder515/08/2016 07:10:45
2878 forum posts
248 photos
To remove the door, undo the electric plugs etc etc etc ... Not very helpful I suppose.
BobH
Michael Gilligan15/08/2016 07:38:54
23121 forum posts
1360 photos
Posted by Speedy Builder5 on 15/08/2016 07:10:45:
BobH
To remove the paint, without removing the door; see Ajohnw's thread about pressure washers.
[Sorry]
Sam Longley 115/08/2016 08:02:08
965 forum posts
34 photos
Depends where it is & how big but perhaps he could source a little lable or rondle etc something like that. Ie a security tag ( if near the lock) etc & put it over it so it looks as it is supposed to be there
David Jupp15/08/2016 08:07:59
978 forum posts
26 photos
Superglue shouldn't set if it has free access to air, so should be able to wash off with warm soapy water. The edge of a credit card or similar can be used as a scraper which shouldn't scratch the paint.
Neil Lickfold15/08/2016 08:31:18
1025 forum posts
204 photos
Nitro Methane is the most effective solvent for super glues. It usually does not effect the car paint either. Acetone can attack some car paints. Some superglue de bonders contain Nitromethane.
roy entwistle15/08/2016 13:25:53
1716 forum posts
A big thank you to all, especially Andrew Entwistle ( No relation ) The product from Tool Station worked a treat
No discernable damage to paintwork and only took a few minutes
Roy
