Design ideas needed
Peter Russell 1 | 05/08/2016 16:39:00 |
10 forum posts | I have just finished phase 1 of my latest project - a 5 foot long rear paddle steamer - at present powered by an electric motor. Phase 2 is steam power and I'm well on, having built the boiler and started on the cylinders. What I need now is information- and possibly a proven design- for a gas torch burner for the boiler. The fire tube is 1 inch od, so the burner has to fit that. If anyone can point me in the right direction I would be grateful. Thanks. By the way, if anyone's interested, you can see the development of the steamer here:- www.steamrail.co.uk |
Chris Shelton | 05/08/2016 19:35:32 |
![]() 92 forum posts 46 photos | It might be worth having a look at myfordboy on YouTube, part 12 of his constructing a traction engine article, which uses a cheap pencil gas torch as the basis of the gas burner. HTH |
Peter Russell 1 | 07/08/2016 08:22:05 |
10 forum posts | Thanks for that, but I think it might be a bit too small. My boiler is about twice the size of his so it's going to need a lot of heat.
Ian S C | 07/08/2016 12:43:15 |
![]() 7468 forum posts 230 photos | I have seen a burner in the form of a Bunsen burner with the end blocked, and holes along the barrel for the flames. I think it was about 1/2" diameter x 4" long. Ian S C |
duncan webster | 07/08/2016 15:17:15 |
5307 forum posts 83 photos | If you want a torch type burner why not buy one from Sievert, or canibalise one off a blowtorch? If you want a poker type then **LINK** is quite good. If you want radiant heat (might be optimistic inside a 1" tube) then **LINK** look good. I think Cheddar used to make something similar, but can't find them on the interweb |
Peter Russell 1 | 08/08/2016 17:08:36 |
10 forum posts | Thanks for that guys. You have given me a few ideas. I've got a spare Ronson gas torch lying in the workshop. I think its about to be modified.
Peter.
