Cornish Jack | 26/07/2016 13:04:42 |
1228 forum posts 172 photos |
The above photo's are of a motor and impeller from a dismantled grinder dust extractor cabinet. The cabinet is too heavy for me to use it but the motor is a capacitor start job in excellent condition. I would like to recover it but the method used to mount it has me totally foxed. The three complete circumferential holes and the central one are internally threaded - unknown pitch/ LH, RH???. There appears to be a key of sorts on the central shaft. Have any members come across similar fixings or any suggestions as to how to start the removal process, please? If all else fails, I'm considering chain drilling and general savagery!! rgds Bill |
Journeyman | 26/07/2016 13:15:14 |
![]() 1257 forum posts 264 photos | It's a taper lock bush. It is missing the screws normally allen head grub screws. Two screws hold it on and the third is a jacking screw to remove it. See Fenner for more info. John |
Mike Lightfoot | 26/07/2016 13:18:07 |
76 forum posts 24 photos | John you just beat me to it failing a screw to jack it off usually a smart tap on the fan boss should push it back enough to get it off good luck
Cornish Jack | 26/07/2016 14:24:19 |
1228 forum posts 172 photos | Thank you very much, Journeyman and Mike L. Exactly what was needed. The body of information among forum members is amazing, remarkably comprehensive and reassuring for we 'less sharp blades in the knife box'!!! rgds Bill |
Vic | 26/07/2016 14:24:42 |
3453 forum posts 23 photos | Glad you're sorted. The motor looks to be in good condition from the casing. Edited By Vic on 26/07/2016 14:27:45 |
Cornish Jack | 28/07/2016 22:49:39 |
1228 forum posts 172 photos | Just an update - the job is done! and, Vic, yes the motor (2840/1hp?) IS in good nick rgds Bill |
