Mark P. | 15/07/2016 09:14:05 |
![]() 634 forum posts 9 photos | Hello all, can anyone tell me if they know of an online gear calculator? I know the ratio (1.89:1) but I think that I could get away with 2:1 I also know the center distance of the two gears 103.77mm and the MOD 1.25. But the more I look at the formulas for calculation the more confused I get, I must say that formulas are not my strong point, hence my quest for an online gear calculator. Regards Mark P |
Brian Wood | 15/07/2016 09:24:26 |
2742 forum posts 39 photos | Hello Mark P, This may not be quite what you are looking for, but you can get gearing in the form of 17 teeth driver to 9 teeth driven to give you a ratio 1.888 recurring to achieve a very close approximation to 1.89:1. So, gears of 85/45 if you have those would do what you need [these are the simple multiples by five of the values 17 and 9 Regards Brian |
Neil Wyatt | 15/07/2016 09:39:12 |
![]() 19226 forum posts 749 photos 86 articles | Mark, you have a personal message. Neil |
duncan webster | 15/07/2016 19:11:56 |
5307 forum posts 83 photos | module is pcd (mm)/teeth, the inverse of diametral pitch. If you flog through the arithmetic you get either 108/58=1.86 or 57/109 = 1.91, both with a centre distance of 103.75 mm |
John Stevenson | 15/07/2016 20:41:25 |
![]() 5068 forum posts 3 photos | In 1.25 Mod 106 / 56 will give you 1.8928 as a ratio with a centre distance of 101.25mm
Or 108 / 58 wil give you 1.86:1 at a centre distance of 103.75 |
Mark P. | 15/07/2016 20:52:21 |
![]() 634 forum posts 9 photos | Thank you all for your help, I seem to have been chasing my tail, maths have never been my forte. Regards Mark P. |
mick H | 16/07/2016 06:26:43 |
795 forum posts 34 photos | Try "GEAROTIC". Mick |
