PTFE piston rings
duncan webster16/06/2016 16:09:35
5307 forum posts
83 photos
Just bored the cylinders for my latest loco (gunmetal). There are some pinholes at one end of both castings. Can't send them back as I bought them second hand, anyway I'm not sure it's that bad. I'd like to try PTFE rings, backed up with an O-ring to give the out spring. I'm sure this has been done, but I can't find any reference in previous threads. Anyone got actual experience?
fizzy16/06/2016 19:24:42
1860 forum posts
121 photos
I tried this a few years back with bad results. The rings expand after machining and even more so when they get hot . Piston siezed in bore, engine thrown under bench...still there somewhere!
ruston16518/06/2016 23:26:30
11 forum posts
Ive recently had ptfe rings fitted to a 5 inch black 5 i have. And ive gotta say they are superb. No problems at all. They were done by Ben Pavier at BP Loco works, can pass on contact details if needed.
Lee
julian atkins18/06/2016 23:45:24
1285 forum posts
353 photos
Hi Duncan,
I am very old fashioned so would fit graphite square asbestos packing to your gunmetal cylinders properly fitted - which few appear to know how to do properly.
However a friend of mine has recently done extensive experiments with PTFE on piston valves and pistons. I will email you a few links. They take things a bit beyond current thinking.
Cheers,
Julian
John Baguley19/06/2016 02:22:36
517 forum posts
57 photos
I've used them on several 2½" gauge locos with excellent results. Also used PTFE on piston valve heads with equally good results. With these smaller bores though I haven't used backing O rings and just relied on the plain PTFE rings on their own. I fit two thin rings side by side with the gaps 180° apart to prevent leakage. It is essential to allow clearance for expansion when the rings get hot.
I haven't done it yet but I've thought of using graphite filled PTFE for the rings as this material is harder and springier than virgin PTFE and may not need the backing O rings in the larger sizes.
Brian Oldford24/06/2016 20:59:46
686 forum posts
18 photos
Is the shared wisdom to include a bell-mouth at the end of the cylinder to assist with insertion of the rings à la full size practice?
