Minature J&S style toolholders
Rainbows16/04/2016 17:37:22
658 forum posts
236 photos
I recently got a batch of J&S toolholders in an auction lot and while they are too big to fit anything I own (hey if anyone wants em I could sell em) I have taken a shine to the underlying idea of the back rake being built into the toolholder.
Does anyone know if tinier ones are made? My size would be 4-5mm HSS and a shank up to 1/2". Failing that, does anyone know if they ever have been made so I can copy the design and build my own.
OldMetaller16/04/2016 17:47:11
208 forum posts
25 photos
I've got a lovely J & S that just won't quite fit into the four-way tool post on my ML7, I can't bring myself to vandalise it by grinding it down...
It would be great if some smaller J & S-type toolholders were available.
John.
mark smith 2017/04/2016 12:55:11
682 forum posts
337 photos
I have some that were already vandalised to fit a southbend 4way toolpost ,i also quite like them they are pretty solid .
I think they came in several sizes .
Edited By mark smith 20 on 17/04/2016 13:00:54
Ian S C17/04/2016 13:00:51
7468 forum posts
230 photos
I'v got a left, right, and straight 1/4" ones, but they need packing in my lathe. Probably my most used tools.
Ian S C
Clive Foster17/04/2016 13:27:47
3630 forum posts
128 photos
Smallest common size is the flat bottom 5/8" x 3/8" shank version taking 1/4" toolbits. Nominal minimum tooth height above the base is 1/2" with nominal 1/8" (ish) projection. I have examples badged Armstrong / Denford / Andycraft / Homecraft in the "why are you keeping those" box. All subtly different but close enough that you need to read the name to see which one you have grabbed. J&S may have made a similar size with their typical dropped front design. I imagine the shank would have been 1/2" x 3/8" putting the tooltip about 1/8" lower. Obviously needs to go in a block, 4 way or lantern type toolpost to accommodate the drop but flat bottom ones can go direct on the topside. I want to say that I've had J&S types in that size through my hands and let them go with my SouthBend Heavy 10 for which I made multiple 4 way toolposts to use as a poor boys QC system but bottom line is I can't recall exactly what I had.
There is a 1/2" x 1/4" nominal shank size version taking 3/16" toolkits. Seems to be very rare as I've only ever seen the one which came with my first lathe, a Portass S. Disappeared sometime in the intervening 40 + years but I suspect it was made by Eclipse to match their smallest parting blade holder, 2 of which I still have.
Clive.
