Best mini grinder bits
michael cole26/03/2016 10:34:39
166 forum posts
I have a dremel type mini grinder. I use it either to grind surfaces ,like cleaning up a casting or to clean up the egde of thin sheet. I just cut some 1.2 mm SS sheet.
Do you perfer the sanding drums or to use a stone? I find that the stones i use are very soft and wear away quickly. Does anyone have good results with the tiny milling cutters type?
roy entwistle26/03/2016 10:39:19
1716 forum posts
Try the diamond bits
Hollowpoint26/03/2016 10:54:14
550 forum posts
77 photos
You want the orange aluminium oxide grinding wheels. Forget the cheap ones get the proper dremel branded ones. They last about 4-5 times longer. I like the 952 cone shape best.
Edited By Hollowpoint on 26/03/2016 10:55:35
JasonB26/03/2016 12:20:42
Posted by Hollowpoint on 26/03/2016 10:54:14:
That's what I tend to use on castings, linisher is quicker on sheet material edges.
michael cole26/03/2016 12:50:50
166 forum posts
Posted by JasonB on 26/03/2016 12:20:42:
But I am cleaning up the inside edge of holes on sheet steel, Linisher will not work.
speelwerk26/03/2016 16:47:02
464 forum posts
Not cheap but also very good is **LINK** , it is more difficult to control those tiny milling cutters by hand.
Niko.
Neil Wyatt26/03/2016 17:00:11
19226 forum posts
749 photos
86 articles
I prefer the emery drums for cleaning castings, with a diamond burr for tight corners
I suspect this is very much something that is personal preference and the type and size of casting you usually use.
