check valves
What type do you use?
Simon Collier13/03/2016 00:36:15
525 forum posts
65 photos
What type of clacks are people using, traditional ball type, o-ring seats or shuttle valve with o-ring face? I never seem to have much success making ball seats, despite all possible care, that totally seal. The same procedure produces hit and miss results. Bought ones are no better, some good, some not. I bought a set of oil and water check valves of the shuttle valve type, some time back, as yet unused, but I have heard only bad things about them. Are they any good?
mick H13/03/2016 07:01:21
795 forum posts
34 photos
Using a Viton ball instead of the usual stainless steel ball will give a good seal. The Viton ball should be "one size" larger than the steel ball.
Mick
Phil Whitley13/03/2016 09:29:00
1533 forum posts
147 photos
If you use a brass bodied fitting to make a non return valve with a ball bearing and a spring, the magic trick is to seat the ball into the brass by giving it a sharp tap with a hammer and a flat ended punch. I have made non return valves for compressors using this method, and they don't leak!
Phil
i
HOWARDT13/03/2016 09:29:01
1081 forum posts
39 photos
Years ago I used to make a high pressure ball valve, 2500psi, with a stainless ball in a brass fitting. We used to place a ball on the hole and strike it once, then build it with a new ball. Worked every time. That ball was around 5mm in diameter. On another assembly we used carbide seats and glass balls, 750 to 1500psi. These had to work out of the packet, you can't deform glass or carbide 😀😀.
John Fielding13/03/2016 10:08:00
235 forum posts
15 photos
Car tyre valves (Schrader valves) also work well and cost almost nothing. Grab a handful from your local tyre fitters as they cut them out and toss them in the bin when replacing tyres.
mick H13/03/2016 15:06:14
795 forum posts
34 photos
Posted by John Fielding on 13/03/2016 10:08:00:
This sounds like a good idea. What is the opening pressure for a standard Schrader? Can the idea be successfully extended to safety valves? Given the application of these valves they must surely be manufactured to a very high standard.
Mick
julian atkins13/03/2016 21:54:20
1285 forum posts
353 photos
Schrader valves are not a good idea on miniature loco boiler. on a hydraulic test they float.
cheers,
julian
Simon Collier13/03/2016 22:06:30
525 forum posts
65 photos
Perhaps my sharp tap isn't sharp enough. I found and re-read the article on clacks by Gordon Smith in EIM Jan 2015. It is excellent but doesn't mention making the ball seat. His design does include a separate screwed in seat which allows the seat to be faced square with a fine finish. Thanks for the replies. I'll have a go at making one or two this week.
duncan webster13/03/2016 22:29:37
5307 forum posts
83 photos
Dont forget you have to ream (or better still bore) the hole in the seat, as if it isn't truly round you will have the devil of a job getting a seal. Realistically it's too small to bore, so I use a D bit. Finish by very small facing cut from the inside to the outside, then you won't get any burrs. Instead of biffing it, if it is a screw in seat you can burnish it, stick a ball on the end of a bit of rod, spin the seat in the lathe and present the ball to it. You can inspect the seat with a loupe, if you see a shiny line all round it will seal, if not it won't.
Simon Collier14/03/2016 01:10:15
525 forum posts
65 photos
I am aware of the need for a round hole. I can make a D bit easily but what about a slot or end mill? Hard to see how they could make a poor hole, say, drill 3.5 mm and use a 5/32 end mill?
duncan webster14/03/2016 10:51:55
5307 forum posts
83 photos
Never tried it, but I suspect the end mill will act like a little boring bar and only cut on one tooth. Hole size will be dubiious. I've used toolmakers reamers in the past for similar jobs, easy to make, easy to sharpen, easy to use, just drill a hole a few thou undersize then poke the reamer through. All in the lathe of course, by hand might be iffy.
John Fielding14/03/2016 12:12:56
235 forum posts
15 photos
I use counterbores for forming flat seats with a hole in the middle. They are freely available for most sizes of imperial and metric bolts. I gave up on D bits years ago!
HOWARDT14/03/2016 15:28:30
1081 forum posts
39 photos
Roundness of the hole doesn't matter that much if the ball is struck to leave a complete circle of indentation. The hole is only an outlet and allows the ball to be positioned. Using a slot drill or end mill will not leave a flat face unless the cutter is well ground and the spindle is square to the part.
Boiler Bri06/11/2016 11:55:53
856 forum posts
212 photos
Does anyone have a drawing of a 'different' style of check valve say with the ball seating off to one side?
The tee type are ok but I want something different for my 4" Durham engine boiler side feeds.
Bri
