Nick_G | 21/02/2016 03:29:46 |
![]() 1808 forum posts 744 photos | . I have a set of drawings from American origin for an engine I am considering building. They list for certain parts a grade of steel as A311. This stuff :- **LINK** What is the UK EN designation for this please. I have looked on the web, but it's all Greek to me. Cheers, Nick
Edited By Nick_G on 21/02/2016 03:32:09 |
Peter Krogh | 21/02/2016 03:50:38 |
![]() 228 forum posts 20 photos | It's most commonly known here in the US as 1144. That might yield a better search result for you. Pete |
Roger Provins 2 | 21/02/2016 07:25:10 |
344 forum posts | There was and early post on this subject. http://www.model-engineer.co.uk/forums/postings.asp?th=44783 Edited By Roger Provins 2 on 21/02/2016 07:26:43 |
JasonB | 21/02/2016 07:27:30 |
![]() 25215 forum posts 3105 photos 1 articles | Yanks favorite metal for model crankshafts. I either use black Mild steel which does not move about much or EN8 and take care to balance the cuts and let it rest. Or go for a built up crank. Basically its heat treated to remove any internal stress so won't move about when you start making unbalanced cuts in it. |
Raymond Anderson | 21/02/2016 07:31:08 |
![]() 785 forum posts 152 photos | Hi Nick, A311 is an ASTM designation, the equivalent AISI code is as Peter mentioned AISI 1144. [ Stressproof ] I have used it a few times and it is tough, but nice to machine. Not quite as tough as AISI 4340 [EN 24 ] . With the correct insert it can leave a lovely surface finish. |
JasonB | 21/02/2016 08:11:05 |
![]() 25215 forum posts 3105 photos 1 articles | If its the engine we were talking about then substitute EN1A for the cam lobe blank and Stainless 303 for the valves. J |
Nick_G | 21/02/2016 11:19:23 |
![]() 1808 forum posts 744 photos | . Cheers guy's. Yes Jason it is that Hoglet V twin. Nick |
William Howcroft | 15/12/2020 11:44:58 |
12 forum posts | https://tubingchina.com/1144-Stressproof-equivalent-steel.htm |
