Simplex Restoration
Ryan John17/02/2016 11:41:43
4 forum posts
Hi Guys,
I am new here, and I am undertaken a resto project on a 5 inch simplex.
I don't have access to any machines was hoping that I could get a third party to make some boiler fittings for me, All I really need is the regulator steam dome fitting to boiler and lower water gauge (circle bolts) fitting.
Does any one know as to where I will be able to get such service?
Thanks
Neil Wyatt18/02/2016 20:39:43
19226 forum posts
749 photos
86 articles
Welcome to the forum Ryan,
I'll >bump< your question
David Wasson18/02/2016 21:15:16
149 forum posts
43 photos
If you are in England, John Baguley has made several Simplex parts for other folks. Do a search and you will fine his website. Give him a try.
David
Ryan John19/02/2016 19:01:57
4 forum posts
Thanks Neil and Thanks David I will send John an email.
Also another question with the boiler it has no paper work or numbers and is deffo an home made boiler, now I am right to understand that the boiler can still get papers if it is hydro tested 2x working pressure stripped then 1.5x hydo with fittings and then steam test? Or did I dream that? lol face 22
julian atkins19/02/2016 20:09:29
1285 forum posts
353 photos
hi ryan,
re the boiler i am afraid these days it rather depends on what view your club boiler inspector takes. generally, a miniature loco boiler without any paperwork is regarded as 'new' and not having complied with the current boiler regs re inspection throughout the build process of internal joints - now hidden in your case.
some clubs are stricter than others. a lot will probably depend on the external condition of the visible joints, especially the foundation ring.
usually a boiler without paperwork or pedigree is regarded as scrap. but again this depends on the discretion of the club boiler inspector.
cheers,
julian
David Wasson20/02/2016 00:40:30
149 forum posts
43 photos
If the boiler is home-made, it is probably made as per the original Simplex drawings. The drawings are easily available. You can then at least inspect the boiler externally to see if it matches the drawings. Having the drawings and passing all of the cold and hot hydro and steam tests should be good enough for many inspectors. In don't believe there is any history of Simplex boiler failures when built as per drawings.
David
julian atkins20/02/2016 22:45:41
1285 forum posts
353 photos
hi david,
the issue is the standard of the hidden internal joints, not the design - though you know my views on the Simplex original boiler design.
ive cut up 2 boilers that failed a hydraulic test. on one the tubes fell out of the inner firebox tubeplate during hacksawing. on the second the penetration of silver solder around the inner hidden joints especially the inner firebox wrapper was non existent.
cheers,
julian
David Wasson20/02/2016 23:25:29
149 forum posts
43 photos
Aren't the internal joints soldered first and then inspected, at least visually? Any tube soldered into a tube plate that did not have the solder flow well, it would seem pretty obvious before going any further with the job. One end of a tube goes into the smoke box tube plate and the other end goes into the firebox tube plate. These joints should be absolutely perfect, at least visually before going any further with the boiler construction. Most boilers are constructed in pretty much the same way. Tubes should not be falling out when scrapped. If a joint is suspect, stop and make it right before going any further. Page 430 of ME May 3, 1968 shows the inner fire box and tube assembly of a standard Simplex boiler. At this stage of construction, both sides of each tube joint on each end, can, and must be inspected.
The only place on a Simplex boiler that I might change is to add a flange on the throat plate.
Simplex boilers that cannot pass the hydro tests will never be used, just like any other boiler. This is of course not a knock on Simplex boilers, just poor workmanship.
Sounds like the boilers you cutup were simply not made well, not designed poorly, as you have said.
David
julian atkins20/02/2016 23:35:36
1285 forum posts
353 photos
hi david,
this is why ryan's boiler would be treated these days by UK club boiler inspectors with a considerable degree of caution. it has not undergone the stage by stage examination under the current regs. plus there is no paperwork and no pedigree. unless you use an endoscope you have no idea how good the internal joints are.
cheers,
julian
David Wasson21/02/2016 01:58:13
149 forum posts
43 photos
So, a boiler that passes all of the hydro tests will be rejected because it was not scrutinized step by step during construction? That's pretty hard core.
Or, if a boiler passes all required tests, does it get certified anyway?
David
julian atkins21/02/2016 11:22:05
1285 forum posts
353 photos
hi david,
at the risk of repeating myself, in the UK you are unlikely to get a club boiler certificate from a club boiler inspector for a boiler without any paperwork or pedigree. things are much stricter these days. passing the initial 2 x WP hydraulic test is but one stage, and in any event doesnt always show that the boiler is soundly constructed
there have been many instances of say locos being bought off ebay without any paperwork or pedigree and a boiler certificate has been refused. however this is a matter for the discretion of the club boiler inspector.
cheers,
julian
Ryan John21/02/2016 11:31:11
4 forum posts
Hi all, sorry didn't mean to open a can of worms. I went a should the boiler to an inspector yesterday who said he will be then happy to test once I have made up the blanks, he was happy with the thickness of copper and the crown had no signs of foul play. So fingers crossed all will be ok, I was also told of a rivitted vertical boiler that had no paperwork but after clean up they happily tested a certified.
Fingers crossed, the simplex now runs like a dream on air even with a Stevenson linkage! Just need blanks now, was thinking for inner dome Bush blank designs on solidworks and get laser cut, what thickness would you recommend?
Russell Eberhardt21/02/2016 11:46:40
2785 forum posts
87 photos
So, according to Julian, a boiler of unknown pedigree or even one that has been made to EU regs by an amateur cannot be used even if it passes all the pressure tests. What then is the point of the pressure tests?
. . . and people in the UK complain about having to meet European rules!
Russell (in France)
Neil Wyatt21/02/2016 12:15:55
19226 forum posts
749 photos
86 articles
In fairness to Julian, I can imagine several circumstances where a pressure test alone is not proof of a safe boiler. An example would be where the boiler wrapper is too thin - able to take the pressure but easily vulnerable to damage.
Ryan John21/02/2016 12:50:32
4 forum posts
Posted by Neil Wyatt on 21/02/2016 12:15:55:
Oh with out a doubt, I think a boiler should not be tested if it looks a thick as say a coke bottle say, but made to drawings, I think its a case of using common sense, The clubs boiler inspectors should be competent enough to decide to test a boiler and when to deny even a test.
But I feel there should not be a blanket ban, and maybe even better understanding by the feds as its not black and white.
David Wasson21/02/2016 13:29:09
149 forum posts
43 photos
Yes, common sense should certainly prevail. A boiler that has been made as thick as a coke bottle, has not really been made to the drawings. A failed boiler, by definition, has not been made to drawings either. A poorly made boiler is self correcting, it will fail and never be used no matter what.
A potential problem I see, as described by Julian, is that a boiler can only pass if it has been witnessed step by step during construction and then passes the tests. What happens if the inspector dies or leaves the club? Now he is gone and there is no "witness" for your boiler construction even though it still passes the tests? This makes no absolutely no sense and is counter-productive to the hobby.
Yes, I do hope the boiler inspectors use more common sense versus tossing out a boiler simply because no one witnessed the construction. Sounds like Ryan's inspectors are more than likely doing the right thing.
Edited By David Wasson on 21/02/2016 13:30:06
Edited By David Wasson on 21/02/2016 13:31:12
Jeff Dayman21/02/2016 18:14:01
2356 forum posts
47 photos
If a copper boiler passes a hydraulic test and appears to be of good construction and workmanship generally, and then passes a steam test, I can't really see how an inspector can rationally fail such a boiler, regardless of where it came from.
If a club inspector failed such a boiler I think it's time to join a different club. Tinpot dictators are ten a penny at many clubs of all kinds in my experience. When successful test results are overruled by such dictators and rule makers it becomes a losing battle and precious hobby time is lost (and any prospect of fun running an engine goes out the window).
As someone mentioned, there is little or no record of model engine boilers failing causing any injuries, over the more than 100 years of the team hobby, so there isn't much to justify excluding a tested safe boiler from use.
Just my $0.02 worth. Your mileage may vary.
JD (not a club member and never will be)
julian atkins21/02/2016 20:18:47
1285 forum posts
353 photos
hi jeff,
i dont disagree with what you say. but it is a matter for each individual club boiler inspector to use his discretion in the light of the current regs for boilers without any paperwork or pedigree.
if everything looks ok from close examination of external and accessible internal joints with good silver soldering then you might be ok.
however i can think of lots of examples where this isnt the case. eg comsol flooded over a foundation ring and outer firehole ring. that would be pretty fatal IMHO.
cheers,
julian
Jeff Dayman21/02/2016 23:07:00
2356 forum posts
47 photos
As I said "If a copper boiler passes a hydraulic test and appears to be of good construction and workmanship generally, and then passes a steam test, I can't really see how an inspector can rationally fail such a boiler"
Why would "comsol flooded over over a foundation ring and outer firehole ring" be "fatal" to a boiler that passed tests as above?
You are sounding like a biased boiler inspector rather than an engineer basing conclusions on observed successful tests. JD
julian atkins21/02/2016 23:19:33
1285 forum posts
353 photos
Jeff,
i dont want to disagree with you. it is up to an individual UK club boiler inspector's discretion.
comsol flooded over joints (rather than non silver soldered stay heads) indicates a poor attempt to cover up bad penetration of the final (perhaps most difficult) joints. comsol wont cure a bad silver soldered structural joint. it is only a caulking medium and has no inherent strength.
cheers,
julian
