Ring LED light
BOB BLACKSHAW13/02/2016 04:59:18
501 forum posts
132 photos
Hello
I am looking to put a LED ring light on my milling machine after reading about the idea from a American web site. The only type I can find is the type used for flash photography, the size is ok but that is about all. Any idea where one can be purchased at a reasonable price, as one for microscope use is around £100.
Thanks for any replies
BW13/02/2016 05:16:45
249 forum posts
40 photos
Look up angel eyes on ebay or alibaba.
They are rings of leds used in car headlights.
Should be getting them for $5 to $20ish.
or $100s for rolls royce
http://www.ebay.com.au/itm/2x-70mm-1210-3528-21-LED-Car-Angel-Eyes-Halo-Ring-Light-Headlight-White-Light-/361350524157?hash=item54222b6cfd:g:zf4AAOSwHaBWjjYA
Bill
Edited By Bill Wood 2 on 13/02/2016 05:21:25
Matt D13/02/2016 09:18:05
8 forum posts
At work we use the led belts or strips for various things. Maplin code N91NA are 12 volt ones but I expect that they are available in different voltages and from RS etc. Not expensive but they would need protection. Could you make and mount a suitable holder?
Ian Welford13/02/2016 09:23:07
300 forum posts
I,be done this. Look up angel eyes on e bay type site. Buy the diameter you need, also buy one of the transformers (about £5 ) or so to convert 240v to the stable 12v you need. Double sided tape works well to secure in place ( foam pad type ) but clean the area with solvents first. Hammerstein thinners is good for this.
An old coffee tin lid with suitable hole cut out works as a reflector. Good luck. Ian
OuBallie13/02/2016 09:49:13
1181 forum posts
669 photos
Fitted those to my drilling machine and Marlow mill.
You need a larger diameter than you think, as the chucks throw a shadow onto the workpiece.
I've bought larger ones, but need to fit them.
They do work well though.
Don't all feint now, but I am busy replacing the gears in the BH600G's Apron.
Geoff - Usual comments welcome smiley
