John Munroe | 10/02/2016 19:10:40 |
50 forum posts | Hello I'm trying to design a small metal telescopic track (6cm x 2cm when extended) where small objects may be arbitrarily positioned inside. Here's an example:
In the above example, the green block jams the tracks as the bottom cannot move upward. Does anyone know of a better design such that the tracks won't be jammed? I've thought about putting a sleeve on the inside, but if it was 6cm long and covers the entire extended length, it'd overhang when retracted. Any help will be appreciated. Thanks |
pgk pgk | 10/02/2016 19:25:52 |
2661 forum posts 294 photos | can you simply reverse the system and have the wide end as the discharge end..any 'jams' hopefuly being discharged on withdrawal. Or if you don't need access to the top of the shute then a sprial with a flexible inner sheath? Or is it acceptable to have an upward or downward folding hinge midway? |
John Munroe | 10/02/2016 19:48:18 |
50 forum posts | Posted by pgk pgk on 10/02/2016 19:25:52:
can you simply reverse the system and have the wide end as the discharge end..any 'jams' hopefuly being discharged on withdrawal. Or if you don't need access to the top of the shute then a sprial with a flexible inner sheath? Or is it acceptable to have an upward or downward folding hinge midway? Unfortunately both ends are supposed to be used for discharged. The setup is rather small, so I think hinges will fit in there. I'm not sure if I completely understand, but how does a spiral work here? Thanks
pgk pgk | 10/02/2016 20:03:26 |
2661 forum posts 294 photos | I had something like a spring type spiral supporting an inner flexible liner (so it's a tube when extended) then control it in various ways..perhaps as simple as a thread and rotating nut under the permanent section so it concertinas when closed. |
Danny M2Z | 10/02/2016 20:08:01 |
![]() 963 forum posts 2 photos | Hi John. Would a bevel on the inside edges of the smaller channel section be of any use? * Danny M * |
John McNamara | 11/02/2016 07:29:21 |
![]() 1377 forum posts 133 photos | Hi John The green part is behaving in a similar way to the wedging cams in a Sprag clutch. A little friction and the very powerful wedging action takes over. I can see this problem happening not only with one part but 1.5 parts or more as well. They can press against each other and you have a jam. It would help if you defined the problem in a little more detail. Regards Edited By John McNamara on 11/02/2016 07:30:30 |
John Munroe | 11/02/2016 13:48:15 |
50 forum posts | Hi John, I've thought about a blind type base, but I worry about wear and tear as the base would need to be rather thin to keep the small package. These are actually parts of two parts that are separated by a spring. The spring is compressed when the two parts are pressed together. Inside the chutes, there can be arbitrarily positioned blocks. I wonder if the jamming issue could be resolved by giving the chutes a better finish, e.g., 1.6Ra? Perhaps, the gaps between the two could be reduced? Would it be reasonable to make the gaps 0.05MM on each side (so that lubricant won't get squeezed out)?
Thanks John |
John McNamara | 11/02/2016 14:50:06 |
![]() 1377 forum posts 133 photos | Hi John Trying to think outside the square?? You mention a spring is it steel? can it be attracted to an electromagnet attached to an air cylinder powered arm that could be programmed to pick the part and then drop it across the gap? Assuming the pressed together parts are locked together and do not easily come apart could a vacuum system be used to simply suck them up? Could the part be blown across the gap with compressed air into a wide funnel ? |
Neil Wyatt | 11/02/2016 15:30:15 |
![]() 19226 forum posts 749 photos 86 articles | Pez dispenser? Neil |
mark costello 1 | 11/02/2016 17:17:45 |
![]() 800 forum posts 16 photos | Could You put a double thickness of material 0n the sides of the small slide and mount it underneath? |
frank brown | 11/02/2016 20:13:18 |
436 forum posts 5 photos | use two square sections each with both ends cut into fingers, so the fingers 100% interlock when closed up and you get gaps at the ends of the fingers when the gizmo is extended. Frank |
frank brown | 11/02/2016 20:34:19 |
436 forum posts 5 photos | Suggestion #2 If you need to keep the general shape i.e. a small one inside a big one. Then fix a couple of wires to the end of the small section on each end face and mill a couple of slots per side and bottom of the large one. Use a slitting saw so the hole is smaller on the inside. So now with the hopper in either of its position, at the transition the cargo will ride along the two bits of wire under it and guided by the bits of wire on the side, but as these have no sharp transitions, the cargo will travel smoothly along. Frank |
John P | 12/02/2016 17:53:48 |
451 forum posts 268 photos | Hi John If you can re-work the track so that it is inclined by 45 deg John |
John P | 13/02/2016 10:04:29 |
451 forum posts 268 photos | Hi John From my previous post i realised that i had made In any event with all the suggestions presented in this thread John |
John Munroe | 14/02/2016 07:15:04 |
50 forum posts | Hi John, Thanks a lot for the drawing. Is the view on the left meant to be a cross-section of the track? If so, is it meant to be of a trapezoidal shape? That is, a wide bottom and a narrow top. Could square objects end up being wedged though, given that the edges exert higher pressures than faces do? Thanks John |
Neil Wyatt | 14/02/2016 09:31:02 |
![]() 19226 forum posts 749 photos 86 articles | Much depends on the shape of the parts and how they can interact with the tubes. Would round tubes be less liable to jam? Neil |
John P | 14/02/2016 10:12:58 |
Hi John The view on the left is the end view of the channel. To some extent you would have to make some test pieces to As you first indicated the extended length is 60 mm which Hope this helps. John |
Clive Hartland | 14/02/2016 11:33:32 |
![]() 2929 forum posts 41 photos | Everything I have seen has a vibrating effect to stop or dislodge jams. Surely there is some way of oscillating the set up for that purpose? Clive |
John McNamara | 14/02/2016 12:39:04 |
![]() 1377 forum posts 133 photos | Hi John I actually have a couple of vibrating feed units, they came from a company that made telephones. There were robotic workstations with pick and place units. The parts were fed from a sorter onto long open tracks that presented them the right way up to the pick and place unit. I guess you would not make one yourself anyway there are many suppliers. The Pair i Have are destined for a shaker table to cast epoxy composite parts on. They are quite massive and must have been made for large objects. Regards |
