Martin Botting 2 | 08/02/2016 18:19:33 |
![]() 93 forum posts 20 photos | Hi again. I have ordered the beast from Mr Warco and I was hoping that if any kindly owner of a WM250 vf could oblige me with a measurement from their machine. I am building a new bench and want to get the height near enough so I would like the height from the top of the bench to the hand wheel for the carriage please. I am sure I asked before in the forum but I can't find the posting. Many thanks in advance Martin
mechman48 | 09/02/2016 12:36:56 |
![]() 2947 forum posts 468 photos | Martin Try here, there may be some relevant info here... George. |
mechman48 | 09/02/2016 12:57:15 |
![]() 2947 forum posts 468 photos | Just been & measured my machine; it is on its OEM stand & to the centre of the cross slide hand wheel measures 985mm but then I'm a short arse at 5' 7" so if your taller ( most people are George. |
Rik Shaw | 09/02/2016 13:53:30 |
![]() 1494 forum posts 403 photos | Martin - Top of the bench to centre of hand wheel is 110mm. I am 6ft tall and hand wheel centre is 1015mm above workshop floor. I built the bench like this so I do not have to stoop. Might be worth mentioning that my bench is on heavy duty castors and fixed to the wall by steel brackets which can quickly be unscrewed. This allows bench/lathe to be pulled away from the wall - carefully - for maintenance purposes (this has already paid of on several occasions.) Hope this helps. Rik
SteveW | 09/02/2016 13:58:03 |
![]() 140 forum posts 11 photos | Make the bench a bit taller and not shorter - you can stand on a duckboard if you find you have to for some jobs. As mentioned stooping is not comfortable long term.
