Hollowpoint | 01/02/2016 22:50:22 |
550 forum posts 77 photos | Has anyone here fitted digital scales to there Boxford lathe? I would like to fit a set to mine and would like some neat mounting ideas. I'd rather not have to start drilling holes into my precious Boxford. |
Ady1 | 02/02/2016 00:42:01 |
![]() 6137 forum posts 893 photos | It's not a big deal drilling holes in your precious lathe as long as it's in a good cause A DRO, like a puppy, is for life |
Nick_G | 02/02/2016 01:31:44 |
![]() 1808 forum posts 744 photos | Posted by Hollowpoint on 01/02/2016 22:50:22:
I'd rather not have to start drilling holes into my precious Boxford. . If you want to fit a DRO to it then you will have no option but to do so to some degree. - Even Myford owners have been known at times to do it to the cast iron version of their perceived crown jewels. I had to drill and tap 'oles' in my Boxford to fit a DRO. It was brave and did not cry, wimper or complain even once. I can recommend the kits sold by Machine-DRO. But be aware that the 'kits' from any source will need some form of adapting to some extent to suit most machines. They are not an unpack it, bolt it on and half an hour later you are ready to go solution. It took me a full day to fit them to both my lathe and millings machine. I would advise the fitting of a smaller profile scale to the cross side due to the Boxford being such a small machine. If you don't you will start eating into the already limited capacity. Oh. ............. And Boxfords ain't precious.! They are a machine tool and not an irreplaceable vintage Bentley or part of the Battle of Britain flight. You could of course try holding the scales and reading heads on with 'Blu-tac'
Nick |
Hollowpoint | 02/02/2016 09:16:39 |
550 forum posts 77 photos | I know my lathe isn't a priceless artifact, I'm just a bit OCD about things being as they should be. I'll find a way, I'm supposed to be an engineer after all! |
John Stevenson | 02/02/2016 11:32:51 |
![]() 5068 forum posts 3 photos | If you are an engineer you have NO right to be OCD, take up knitting instead. |
Nick_G | 02/02/2016 12:00:50 |
![]() 1808 forum posts 744 photos | Posted by John Stevenson on 02/02/2016 11:32:51:
If you are an engineer you have NO right to be OCD, take up knitting instead. . My mate Dennis is certainly not OCD. Your place like this and so untidy John.? Edited By Nick_G on 02/02/2016 12:13:47 |
