Worm wheels and worms
Ajohnw | 21/01/2016 23:53:10 |
3631 forum posts 160 photos | This cropped up some where recently, Where ever it cropped up some one hack sawed the slots needed in the wheel before cutting it by eye. They can be lapped and polished afterwards with another worm. Astro people don't seem to appreciate the advantages of huge worm wheels with lots of teeth. Dividing heads etc do. If perfect they reduce the error in what ever is rotating them by their ratio. When they have an error things aren't that simple but given the way they are produced they tend to be pretty accurate anyway. John - |
Michael Gilligan | 22/01/2016 06:31:00 |
![]() 23121 forum posts 1360 photos | Posted by Ajohnw on 21/01/2016 23:53:10:
Astro people don't seem to appreciate the advantages of huge worm wheels with lots of teeth. . ... Really ... I suppose it depends how you choose to define 'Astro people'. MichaelG. . Edit: If you are interested in making a WormWheel, have a look at these old notes by Chris Heapy. Edited By Michael Gilligan on 22/01/2016 07:02:45 |
john carruthers | 22/01/2016 08:17:30 |
![]() 617 forum posts 180 photos | Bigger is better, the 28" at Greenwich has an RA wheel 5' in diameter. |
Neil Wyatt | 22/01/2016 09:58:51 |
![]() 19226 forum posts 749 photos 86 articles | I'm not convinced pre-gashing and hobbing is accurate enough - the wheel I made that way in my rotary table is not accurate enough. I'm going to make another one and get it cut on a CNC hobbing machine. Neil |
Ajohnw | 22/01/2016 11:40:23 |
3631 forum posts 160 photos | There is a rage on tooth belt drives Michael The old rule on ideal worms wheels was diameter >= the diameter of the scope being used. Neil, many have made them with a fair degree of accuracy, allowing them to rotate freely as they are cut seems to be the key and that goes back to pre wwii. At some point I will try a trapezoidal tap with a good tapered lead in which should get round initial engagement problems. Old advice using home made hobs was to wind in quickly. A metric tap as they are cheaper from china than acme usually is. I own a mount by Meade that Astrophysics used to work on and rebadge - they did 2 main things. Lapped the worm and changed the goto software. Also mounted it on a hefty pier. Considering what is around now I decided to stay with it for if I need a mount this substantial. People are locked into tripods too. Any one who has owned a Vixen GP pier would realise that they are light portable and very stable. In fact I reckon they are quicker to set up too. Trying to get the top of a tripod dead level is a real pain. John - |
