Harrison L5a lathe
Norton gearbox
roger kerry11/01/2016 09:05:02
15 forum posts
HI all,
I want to strip my norton gearbox thats fitted to a Harrison L5a lathe. I have the gearbox off the lathe & partially stripped, but am unable to work out how to remove 2 of the shafts & corresponding gears.
Can anyone help with advise or know where i can find info in a manual or publication??
Any help greatly received..!!
Many thanks
Roger
Kettrinboy11/01/2016 20:09:03
94 forum posts
49 photos
p1010275.jpgHi Roger
a fellow L5 owner here , i have taken a couple of photos out of my owners manual of the norton gearbox assy and spare parts list , hope you can make out the detail , i think some taper pins may be involved in retaining things but i havnt had to go this deep into my lathes workings yet so dont know for sure, my lathe is 1963 vintage so this handbook will be for machines of that era presumably.
Edited By Kettrinboy on 11/01/2016 20:11:16
roger kerry11/01/2016 21:48:16
15 forum posts
Many thanks for your help Geoff.
unfortunately i have these already.
Anyone else out there with any more info greatly appreciated
Thanks Roger
Kettrinboy11/01/2016 22:50:36
94 forum posts
49 photos
Ah ok , you could try [email protected] perhaps someone on there could help
roger kerry12/01/2016 17:26:18
15 forum posts
Hi kettrinboy
Thanks for the link. I have emailed the question & awaiting an answer.
roger kerry13/01/2016 08:17:14
15 forum posts
Can anybody point me in the right direction for spare parts for the Harrison L5a lathe particularly bronze bushes for the Norton gearbox.
Chris Evans 613/01/2016 14:53:16
2156 forum posts
I will stick my neck out and assume the bronze bushes will be standard bought in items ? If so available from a bearing supplier, I tend to use Simply Bearings. Other suppliers are available.
roger kerry13/01/2016 21:06:30
15 forum posts
many thanks chris, will look into it.
roger kerry21/01/2016 09:18:34
15 forum posts
you were right Chris, the bronze bushes were standard imperial sizes & easy to obtain. But will require drilling for the oil ways
The `reverse shaft`(L5-2-179) & `The bearing`(L5-2-116) are both badly worn & require replacing.
Can anybody point me in the direction of a spares supplier...??
Many Thanks.
mechman4821/01/2016 09:24:22
2947 forum posts
468 photos
Try ...
Chris Evans 621/01/2016 10:03:05
2156 forum posts
Can the reverse shaft be ground to clean up and a bush turned to suit ? Most case hardened shafts have around thirty thou of "case" If you think it is soft after grinding get it tuftrided ?
