Member postings for roger kerry
Here is a list of all the postings roger kerry has made in our forums. Click on a thread name to jump to the thread.
Thread: Adcock Shipley 2s milling machine
26/01/2022 18:41:53
Thanks all.
Looks like the best thing is to firstly purchase a manual for the mill & then look into the relays & also any info regarding adjusting the clutches.
Any other info would be greatly appreciated.
Many thanks Roger.
24/01/2022 19:21:09
Hi all,
i have purchased an Adcock shipley 2s milling machine from a dear friend that has sadly passed away.
All i know is that Brian said "its the electro magnetic clutch"
Is there a known fault, can anyone help??
thanks Roger
Thread: Tailstock WANTED
10/03/2019 10:27:15
I have found some literature that states that the following lathes were very similar but not identical:-
JET - 1024 & 1036
ENCO - 92010
If anyone can help sourcing a tailstock would be greatly appreciated.
03/03/2019 18:28:22
Hi Chris
Many thanks for your advice.
I have been in touch with Dave, his answer was that he never found a source of spare parts.
Therefor either adapt a tailstock from another lathe or find someone breaking said lathe.
Cheers
03/03/2019 10:32:25
I have purchased an 'ALPINE TD-5AH' lathe but its missing its tailstock,
Any help greatly appreciated
Thanks Roger
Thread: Chester MF42B
25/04/2016 08:03:19
Hi all
This may seem like a silly question, but as iam new to using a lathe i need a little help.
How can I tell if my Chester MF42B multi function machine (serial no - 972373)
is a metric or imperial machine.?
Many thanks
Roger
Thread: Raglan vertical milling machine
04/03/2016 23:10:43
many thanks to all.
Roger
04/03/2016 11:16:07
Hi
I have inherited the above mentioned machine, however its been stripped by previous owner. Can anyone offer any help regarding re-building.?? any instructions or schematics would be most helpful.
Many thanks
Roger
Thread: Harrison L5a lathe
21/01/2016 09:18:34
you were right Chris, the bronze bushes were standard imperial sizes & easy to obtain. But will require drilling for the oil ways
The `reverse shaft`(L5-2-179) & `The bearing`(L5-2-116) are both badly worn & require replacing.
Can anybody point me in the direction of a spares supplier...??
Many Thanks.
13/01/2016 21:06:30
many thanks chris, will look into it.
13/01/2016 08:17:14
Can anybody point me in the right direction for spare parts for the Harrison L5a lathe particularly bronze bushes for the Norton gearbox.
12/01/2016 17:26:18
Hi kettrinboy
Thanks for the link. I have emailed the question & awaiting an answer.
11/01/2016 21:48:16
Many thanks for your help Geoff.
unfortunately i have these already.
Anyone else out there with any more info greatly appreciated
Thanks Roger
11/01/2016 09:05:02
HI all,
I want to strip my norton gearbox thats fitted to a Harrison L5a lathe. I have the gearbox off the lathe & partially stripped, but am unable to work out how to remove 2 of the shafts & corresponding gears.
Can anyone help with advise or know where i can find info in a manual or publication??
Any help greatly received..!!
Many thanks
Roger
11/01/2016 08:47:21
Hi to all.
Iam new to this site & forums generally, just a short message to say hello.
I have been a hobby machinest for a few years, so still learning all the time.
Have a Myford super 7 & a Harrison L5a lathe & a Marlow model 3 milling machine.
Iam needing help with my Harrison L5a lathe, will post in the apropriate section.
Many thanks
Roger
