Adding tee slots to lathe top slide
William Pascoe | 05/12/2015 04:12:35 |
5 forum posts | I note in Gary's article he cut tee slots in the top slide of his lathe. I have been considering this modification to my lathe but I'm concerned that it will weaken the cross side. Would Gary be able to share a rough sketch of the end view of his cross slide so I can get an idea of what others consider adequate. Any other comments would be welcome. Cheers Bill Pascoe Australia |
John Hinkley | 05/12/2015 08:05:06 |
![]() 1545 forum posts 484 photos | I have recently carried out a similar mod to my Asian lathe. There was a thread about it that I started a long while ago. Initially I was going to modify a Myford ML7 cross slide but eventually just milled slots in the original one. The story is told in one of my albums. I compared Mr. Myford's cross slide with my unslotted one and determined that there was very little difference, size-wise, so if the slots didn't weaken the Myford one, that would be good enough for me. I don't have the dimensions to hand, but if you're interested, I'll get them later. John |
Bazyle | 05/12/2015 09:37:12 |
![]() 6956 forum posts 229 photos | An alternative is threaded holes. If you put one in each side in the thick bit it would probably cover most requirements. Then if desperate for a fixing in the middle you could make a bridge piece. |
Vic | 05/12/2015 10:02:53 |
3453 forum posts 23 photos | Posted by Bazyle on 05/12/2015 09:37:12:
An alternative is threaded holes. If you put one in each side in the thick bit it would probably cover most requirements. Then if desperate for a fixing in the middle you could make a bridge piece. That's what I did for my ball turning jig. I keep socket set screws in the holes when not in use to keep the swarf out. |
Gordon W | 05/12/2015 10:08:13 |
2011 forum posts | I will second tapped holes-but don't do what I did just drilled and tapped, I was in a hurry. Years later it is obvious that I should have put them on some sort of standard pattern, instead of measuring every time. |
Gary Wooding | 05/12/2015 11:16:51 |
1074 forum posts 290 photos | I did the mod some years ago and have lost the original drawings, but have re-constructed the attached by direct measurements, all shown in mm. See my album called Stuff. The actual slots are approx 160mm long. Edited By Gary Wooding on 05/12/2015 11:19:34 |
jim' | 05/12/2015 11:59:00 |
72 forum posts 6 photos | I also drilled and tapped the cross slide. 4 holes on the top and three on the side, (I made an "L" shape plate). I figured that if I had a crash, it would be better to damage a steel plate than break a cast iron cross slide! It also means that the load is spread over a far greater area |
William Pascoe | 05/12/2015 12:49:25 |
5 forum posts | Thanks every one and especially to Gary for the drawing. I'll have a measure up tomorrow and post my findings. Cheers Bill |
