fizzy | 10/10/2015 20:20:49 |
![]() 1860 forum posts 121 photos | my rather expensive Ryobi hand drill with variable trigger speed is stuck flat out or newt ar all. Its hardly been used! Is it a simple new trigger jobby or is it likely to be more complicated? thanks
Neil Wyatt | 10/10/2015 20:26:10 |
![]() 19226 forum posts 749 photos 86 articles | You can certainly get replacement triggers for Makita - I've repaired one for my stepson. They usually comprise little more than an FET, a variable resistor and a reversing switch. You may have had a wire come lose. Neil |
fizzy | 10/10/2015 20:33:29 |
![]() 1860 forum posts 121 photos | thanks neil..its part no. 984719001 but there are none left anywhere in the whole world! which in itself speaks volumes. any chance of a non electricians guide to testing and evaluating? |
john fletcher 1 | 11/10/2015 09:34:47 |
893 forum posts | As Neil has said there are just three components, you will need to take the drill apart and located the trigger assembly module not always easy, and putting it together again can be a real pain. If you like I can send you a PM regarding testing the Mosfet once you have got the drill apart and have located the MOSfet, which I think might have failed. although I have known the switch to be full of grit etc and its failed. No doubt you have a camera phone take plenty of pictures as you go, as trying to remember where all the location of all the wires later is not easy. Unfortunately other manufacturers switches etc will not fit. You might need to go to a car boot sale and lookout for an identical drill as a source of spare parts. If you do locate the fault and its a complete unit which is needed, a firm by the name of Cars in Boston Lincolnshire has been a good source of spares for me in the past. I think I found them via Google.John |
John Rudd | 11/10/2015 19:32:45 |
1479 forum posts 1 photos |
Cars is actually.....this site.. http://www.powertoolspares.com/buy-parts/#/manufacturer/ryobi-spares-and-accessories/ Need a model number... |
