Coloured lamps
Fireglow lacquer source/formula
KWIL12/09/2015 14:07:53
3681 forum posts
70 photos
I have a need for 25 watt 240 Volt SES (E14) based PYGMY fireglow lamps and have been unable to source same so I am contemplating dipping my own. Just need the right lacquer. Anyone help?
Edited By KWIL on 12/09/2015 14:08:18
mick H12/09/2015 14:30:59
795 forum posts
34 photos
You might like to try transparent ceramic lacquer which is usually available in decent artist supply shops. The lacquer is baked on to the ceramic item so is definitely heat resistant.
Mick
Keith Long12/09/2015 14:32:55
883 forum posts
11 photos
Hi Kwil - Conrad electrical do bulb paint - here - rather pricey though for doing a couple of bulbs. Your better bet might be to change the lamp holders if possible as it looks as though you can get 25W pygmy and golf ball in red but with a bayonet cap fitting. If you can't change the holders have you got room to put some stage lantern gel material in place so that ordinary clear bulbs could be used?
Brian Wood12/09/2015 14:45:37
2742 forum posts
39 photos
Hello KWIL
www.propertyrepairsystems.co.uk
They sell heat resisting paint to well above light bulb temperatures in aerosol cans as well as tins, they might be worth looking at
KWIL12/09/2015 15:00:32
3681 forum posts
70 photos
Thanks everyone, that should start me off!
davidsuffolk12/09/2015 15:04:52
48 forum posts
8 photos
You didn't say what colour you want but assuming red for a fireglow they make plenty of LED E14 bulbs like this one?
http://www.bltdirect.com/minisun-led-golfball-ses-4w-red-40-watt-alternative (says 40w but the bulb is MiniSun LED Golfball SES 4W Red (20 Watt Alternative).
May be too tall as compared to a pygmy bulb but there are others that may be small enough?
Edited By davidsuffolk on 12/09/2015 15:07:10
Edited By davidsuffolk on 12/09/2015 15:07:32
Ian Parkin13/09/2015 13:37:48
1174 forum posts
303 photos
David
My mum had an electric fire with the fireglow bulbs in it constantly blowing
I thought get her some leds..end of problem
Only trouble is the bulbs act like heaters to make the flicker effect with the spinners so leds no use if you have flicker effect too
Clive India13/09/2015 14:47:33
277 forum posts
Is this suitable?
http://www.ebay.co.uk/itm/15w-Coloured-Pygmy-Bulb-Lamp-BC-Bayonet-Cap-Push-In-B22-Packs-of-2-5-or-10-New-/331604998391?var=&hash=item4d3532b8f7
Edited By Clive India on 13/09/2015 14:49:25
John Baguley13/09/2015 18:32:31
517 forum posts
57 photos
These seem to stock the bulbs you want? Unless you've tried them and they are out of stock
KWIL13/09/2015 19:03:38
3681 forum posts
70 photos
John,
At £8 for a single lamp (delivered)!
They do not last that long so cheaper bulbs + expensive lacquer is probably cheaper in the long (or indeed ) short run.
Clive,
That is better but they are BC base, it might be that I can change the lamp sockets over to BC from SES.
Thank you
John Baguley13/09/2015 19:33:12
517 forum posts
57 photos
Yea, not exactly cheap. If they are that hard to source now they can probably charge what they like for them frown
Packmule17/09/2015 22:46:06
133 forum posts
6 photos
Our gas fire uses pygmy ses fire glow bulbs .Fire is made by Gloworm.
Based in Belper I think.
Spare Parts 01773 596090
Don't know price
Bob
V8Eng17/09/2015 23:23:29
1826 forum posts
Have you tried Ebay?
