Round nose tipped carbide lathe tools
Rainbows08/09/2015 21:08:42
658 forum posts
236 photos
Quick question here. What are these tools with round cutters used for? I could imagine ornamental grooving but are they used for general turning? If so what is the advantage over the various more pointy bit types?
Muzzer08/09/2015 21:18:06
2904 forum posts
448 photos
They are sold for profiling but they are going to result in a fairly length cutting edge so I suspect it may be difficult to use them without judder / chatter on our machines. You will probably have to take very shallow cuts but at least should end up with a smooth profile - if you can avoid said judder.
Neil Wyatt08/09/2015 21:28:34
19226 forum posts
749 photos
86 articles
I think they are also used in copy-turning with a probe of the same diameter.
S.D.L.08/09/2015 22:16:48
236 forum posts
37 photos
The smaller diameter ones are also used for profiling railway wheels / tyres etc.
They work very well if not rammed in too hard.
Steve
Nick_G08/09/2015 22:24:37
1808 forum posts
744 photos
I used one with an 8mm shank recently in a fly cutter on the mill. Gave quite a nice result.
Nick
KWIL08/09/2015 22:25:18
3681 forum posts
70 photos
Yes they are for profiling and are easily used on Myford Super 7 sized machines.
I would not use them for general turning. Nothing wrong with the "pointy" ones if you use them as intended, they work well when worked hard but with care. However it is possible to use them for very fine working and a lighter touch. Experience and practice is the mastering of any form and style of cutter.
Edited By KWIL on 08/09/2015 22:26:46
Andrew Johnston08/09/2015 22:34:34
7061 forum posts
719 photos
Posted by Neil Wyatt on 08/09/2015 21:28:34:
Exactly, like this:
And the finished connecting rods:
Paul Lousick09/09/2015 00:15:03
2276 forum posts
801 photos
Used for machining a radius corner. Used a milling cutter with similar tips to machine a "J" weld preparation on the edge of a plate which required a 4mm radius.  Rotate the cutter tip when it gets blunt to get a new, sharp edge.
Edited By Paul Lousick on 09/09/2015 00:19:07
paul 195009/09/2015 07:06:01
143 forum posts
32 photos
use mine all the time best tool i have
