Mystery Instrument
ZEISS Snap Marker? What is it please?
Martin King 206/09/2015 18:25:21
1129 forum posts
Hi All,
Just got this is an auction lot of tooling along with some tractor models and about 15 very odd case drill bits with strange inserts by ISCAR. the bits have longitudinal holes through them, (for coolant?), they look expensive ! laugh
Have not been able to research any idea of what this is used for.
Any help here would be most welcome.
Martin
Roger Provins 206/09/2015 18:46:00
344 forum posts
The only reference I can find is ...
"In this project a simple mirror stereoscope has been adapted to allow for the stereoscopic inspection of X-ray pictures and a Zeiss 'snap' marker ..."
http://link.springer.com/article/10.1007/BF02442296#page-1
Not that I'm any the wiser!
Neil Wyatt06/09/2015 18:50:39
19226 forum posts
749 photos
86 articles
It's a Zeiss "Snap" marker used for chiseling out a circle of emulsion on x-rays so that you can mark a feature.
Only one relevant hit on google! You learn something useless every day
Edited By Neil Wyatt on 06/09/2015 18:51:40
Clive Hartland06/09/2015 19:33:57
2929 forum posts
41 photos
Maybe now totally redundant because of magnetic resonance imaging!
John McNamara07/09/2015 13:53:38
1377 forum posts
133 photos
Hi Martin
I rather like it in particular the serrated Hirth coupling?
Looking at the picture it appears the two two faces can join properly. a very accurate way of indexing two parts
the indexed angles become more accurate with use due to the wear averaging the spacing over time.
One of my dreams is to own a Moore indexing table, a last century marvel that is still in high demand today.
Maybe you could repurpose the device and make a micro version of the Moore table?
mark costello 107/09/2015 17:07:03
800 forum posts
16 photos
Could someone explain this is a regular language?
Martin King 208/09/2015 07:32:24
1129 forum posts
Hi All,
Despite having a VERY rudimentary knowledge of X-Ray diffraction from Uni many years ago I still cannot quite understand what this thing actually does and totally echo Mark's post above laugh
I think this is destined for EBay as it is of no use to me at all!
Martin
Neil Wyatt08/09/2015 09:43:42
19226 forum posts
749 photos
86 articles
It's not clear, but I think that you align the images (manually) for stereoscopic viewing, which means getting rotation and alignment correct.
This beast is then used to place reference marks on the two x-rays so that they can easily be re-aligned.If you don't want to make and re-use stereo pairs of x-ray photos, it is no more than a curiosity.
KWIL08/09/2015 10:04:24
3681 forum posts
70 photos
Not only redundant due to MRI (Magnetic resonance imaging) but also by CT scanning and 3D reconstruction algorithms. Both of which you can rotate which you could not do with the stereo original method.
IanT08/09/2015 10:10:38
2147 forum posts
222 photos
I rather liked John's idea of re-purposing it as a super accurate indexing table - but I will admit to having quite a few odd things still lurking under the bench awaiting "re-purposing" many years later!
I was also thinking about how they cut the radial teeth on the Moore rotary tables - initially thinking it would be easy on the shaper but I don't think it would be quite that simple.
IanT
John McNamara08/09/2015 14:54:11
1377 forum posts
133 photos
Hi All
It you are interested in how Moore tables were made look for Foundations of Mechanical accuracy here:
Worth a browse for other old text's too I found one I have been after for a while.
Martin King 208/09/2015 15:09:15
1129 forum posts
Now listed on the 'Bay!
Thanks to all for the info.
Martin
