Draw bar thread size for a 2 MT Clarkson autolock milling chuck?
Antony Price25/08/2015 15:03:06
36 forum posts
29 photos
Hi
Is anybody able to confirm the draw bar thread size for a 2MT Clarkson autolock milling chuck? I think it might be 5/16 BSF, but when I try a bolt of that thread it only goes in a few turns. It is possible the previous owner has damaged the thread, but before I re-cut it, I would appreciate confirmation that it is 5/16 BSF
Many thanks
Tony
Keith Long25/08/2015 15:13:17
883 forum posts
11 photos
Looking at morse taper tooling on sale the standard drawbar thread on 2MT seems to be 3/8 BSW or M10. Possible that Clarkson used a fine thread but I'd have thought they'd have gone with the normal standard. If the previous owner has modded the thread either intentionally or by accident then all bets are off.
Edited By Keith Long on 25/08/2015 15:26:05
duncan webster25/08/2015 15:14:56
5307 forum posts
83 photos
Mine is 3/8" BSW
peak426/08/2015 01:02:58
2207 forum posts
210 photos
Posted by duncan webster on 25/08/2015 15:14:56:
Mine is 3/8" BSW
As is mine
John Haine26/08/2015 08:15:44
5563 forum posts
322 photos
Imperial mt2 tooling all seems to use 3/8 bsw. Standard studding is perfect to make a drawbar.
Robbo26/08/2015 09:50:26
1504 forum posts
142 photos
3/8"BSW if Imperial, M10 if Metric
S.D.L.26/08/2015 10:51:28
236 forum posts
37 photos
Posted by Robbo on 26/08/2015 09:50:26:
And some will be UNC
Steve
Ian S C26/08/2015 13:06:12
7468 forum posts
230 photos
3/8" BSW, some will be 3/8" UNC, these are both the same pitch, only the thread angle differs, the UNC being 60*.
Ian S C
Bazyle26/08/2015 13:32:26
6956 forum posts
229 photos
Screw a piece of paper/wood/plasticine down it to pick up and measure the thread pitch and the core diameter. At least you have the tool to try things on.
Mike Poole26/08/2015 15:19:41
3676 forum posts
82 photos
The drawbar thread is often etched on the body of genuine Clarkson holders, can be hard to find and read though! If it is metric it usually has a groove machined at the drawbar end
Edited By Michael Poole on 26/08/2015 15:19:58
Edited By Michael Poole on 26/08/2015 15:22:16
Edited By Michael Poole on 26/08/2015 15:22:40
Robbo26/08/2015 19:03:19
1504 forum posts
142 photos
"The drawbar thread is often etched on the body of genuine Clarkson holders"
Like this one:-
Edited By Robbo on 26/08/2015 19:04:23
Antony Price31/08/2015 16:54:55
36 forum posts
29 photos
Many thanks for the responses to my original enquiry. I’ve managed to get back into the workshop today. I’ve attached a photo of both my 2 MT Clarkson auto lock milling chucks. The one on the left is an “S” type. The “S” type is 3/8 BSW. The “unknown ” has CS 7174 etched on the body. Using a drill bit I’ve measured the “core” of the unknown thread, and arrived at 17/64” (0.2656&rdquo ie a 5/16” thread It is not BSF as I first thought (I couldn’t get a BSW bolt to go more than a thread) . Having looked closely, through a magnifier , I found and picked out the damaged thread. I can now get a BSW tap to go the full length of the thread. I’ve just ordered some 5/16 BSW threaded bar!
Tony
