Chester H80 Blade Snap
David Cambridge13/08/2015 20:13:01
252 forum posts
68 photos
I’ve just snapped the blade in my HY80 Chester band saw. I don’t suppose anybody know the correct size blade to buy from http://www.tuffsaws.co.uk/ ?
Chester list the blade size as 1300 x 0.63 x 12.5mm. The closest match on Blade width seems to be 12mm – is this OK ?
The blade has had comparatively little use and seems to have snapped at the weld. Does anyone have any tips on what I can do to get a better life out of the next one ?
Thanks
David
Frances IoM13/08/2015 20:41:08
1395 forum posts
30 photos
the original blade fitted on my H80 also snapped at the weld but I was attempting (very unsuccessfully) to cut a 15mm thick slab of 316 SS at low speed but no coolant - I had ordered a spare bimetal blade from Chesters and that has worked well since tho I have resisted cutting any more SS - the choice of bimetal was following advice on some USA based forum - later ordered an additional 2 bimetal spares one of each size stocked
pgk pgk13/08/2015 21:02:12
2661 forum posts
294 photos
I bought their H128 and the first blade in that lasted no time at all either (at the weld) but the extra spare I'd got has gone on quite well.
Ian Parkin13/08/2015 23:53:30
1174 forum posts
303 photos
If tuffsaws dont know the length then simply measure your old one..then stick a label on the machine with the correct size for future ref
Most of my blades seem to break at the weld .Ian at tuffsaws will reweld them if they fail but i've never taken him up on his offer as I'm sure I;ve had a good life out of the blades before it fails
Gary Wooding14/08/2015 08:19:42
1074 forum posts
290 photos
I got some bimetallic blades from *LINK*
I got some for my 6x4 bandsaw (64.5"x1/2"x14tpi) and some for a friend's HY80 (51"x1/2"x14tpi). The price was very reasonable and the blades are excellent quality. I'm just a satisfied customer.
Edited By Gary Wooding on 14/08/2015 08:20:13
Ian S C14/08/2015 10:20:52
7468 forum posts
230 photos
It's normal here for the blade to be rewelded if it breaks at the weld. It pays to check that there are no cracks starting from the root of the teeth any where around the blade(save you taking it in and getting it rejected). Used to get my blades done here in Christchurch, but the welder died(machine), so all blades go to Auckland.
Ian S C
Jon Gibbs14/08/2015 11:42:41
750 forum posts
Hi David,
I bought a 1/2" M42 blade replacement for my Warco CY90 ( I think this is basically the same model) from Tuffsaws in February and have received fantastic service from Ian at Tuffsaws; receiving not one but two replacement blades since then!
It seems that their M42 blade stock is perhaps too thick and inflexible for this saw with its tight bends and continuous flexing of the blades back and forth to achieve the necessary clearance. I have broken two M42 blades now at the weld and am now trying one of the Tuffsaw's supertuff carbon steel blades which is thinner and hence more flexible.
Ian tells me that he is trying to obtain some thinner M42 blade stock which he hopes will work better for these small saws. In the meantime it may be best to ask Ian's advice which blade he recommends for this saw rather than blindly buying an M42 blade for it like I did.
The blade is 1300 mm long and 1/2" wide.
I hope this helps
Jon
Edited By Jon Gibbs on 14/08/2015 11:44:31
