Wanted: Texturing Tool for Cast Iron Pieces
David Goodsell18/07/2015 22:37:22
1 forum posts
When building a Stuart Beam Engine, I sometimes have to remove flashings from the cast iron pieces with a file, which tends to leave smooth areas. I would like to re-texture those areas so they blend in with the rough texture of the castings.
Is there a ready-made stamping tool that I could hammer against the casting to make the shiny areas look similar to the rest of the rough surfaces?
Thanks.
Apple Valley, CA USA
Phil P18/07/2015 23:05:43
851 forum posts
206 photos
I am sure Jason B will be along soon to show how he does it very effectively.
I believe he uses an electric engraving tool.
Phil
Hopper19/07/2015 05:40:26
7881 forum posts
397 photos
Sandblaster?
JasonB19/07/2015 07:48:01
As Phil says both myself and Ramon tend to use an engraving tool to add a "cast" testure though this is more on softer bronze/gunmetal than iron. I'm not sure if they are made these days but we both have the Wolf engraver.
As you can see from the shiny bits this carb casting has had a fair bit of reworking
And after a bit or retexturing
I have in the past done small areas with a ctr punch just holding in my hand like a pin and tapping on the surface.
Now having said all that is a "sand" texture really right on a 1/12th scale model? On something like that I would be aiming to have little if any sand texture still showing just a few undulations so it still looks like a casting. Have a look at my comments here and also the post before about finishing castings on a 1/2 scale model that prompted the question.
Ady119/07/2015 08:11:20
6137 forum posts
893 photos
Lidl stores sell an engraver for 10 or 20 quid every now and then
JohnF19/07/2015 08:48:23
1243 forum posts
202 photos
Just google Burgess engraver or Burgess vibrio tool and you will see lots of electric engravers.
Another alternative is make a stippling tool, you can do this using silver steel and make the end look like diamond knurling with a three square file, slightly dome the end as well. This is much easier if you have a metal chequering file as used by the gun trade.
Hope this helps John
Involute Curve19/07/2015 10:05:27
337 forum posts
107 photos
It might be a bit harsh but an Air descaler might do it, it leaves this sort of surface after use....
