ADVICE: Petrol tank fixings material?
what should I make it out of?
Russ B13/07/2015 14:50:24
635 forum posts
34 photos
I might need to put a new fitting in a plastic cover which caps off a modern car petrol tank. Can/should I use brass with a Viton seal or would stainless or some sort of engineering plastic or different seal material be better?
A new pump is around £300, there isn't anything wrong with this one, just the fool who was swinging on it and snapped off the original hosetail which is part of the one piece injection moulded partblush
Edited By Russ B on 13/07/2015 14:51:15
Old School13/07/2015 15:27:53
426 forum posts
40 photos
Don't use silicone rubber for the seal
bricky13/07/2015 20:18:24
627 forum posts
72 photos
Hi Russ
I am building a Centaur gas engine and have been looking for fuel resistant gasket.Reeves sell Hylotyte in a tube.I have found Loctite 5922 at Halfords which is resistant to fuels.Hope this helps.
Frank
Russ B14/07/2015 11:20:19
635 forum posts
34 photos
Thanks for the replies, I'll look in to this out of interest but my problem has solved itself, I paid £35 for a new pump in exchange for my old fully working unit with the snapped connector, apparently its common that people just want the pump from the sump, so as it's full working, it holds some value at the breakers and they did me a deal.
Ian S C15/07/2015 12:22:20
7468 forum posts
230 photos
Russ the rubber you need to make things fuel proof is Nitrile, the spec for this is MIL-R-6855 class1. 10/15 years ago I was into making moulds for making rubber components for vintage Willys Jeeps, one part was the rubber gasket for the pouring spout for the war time vintage Jerry Cans, the old ones were a bit stuffed after 70+ years, so we made a hundred of those fron Nitrile, or some may know it as Buna -N. These bits were made for the Canterbury Military Vehicles Club, and I think some of our stuff got to the States. Seem to have lost the moulds in the earth quake of 5 years ago.
Ian S C
