spanners and nuts
capnahab27/06/2015 07:10:59
194 forum posts
17 photos
I need to replace the topside lock nuts on my lathe (1956 made in Yorkshire). The spanner that fits them is 13/16. Can anyone direct me to a table that will tell me what size nuts to buy ?.
JasonB27/06/2015 07:31:17
allowing for a bit of slack then either 7/16" Whit or 3/8" BSF have a 0.82" AF against your 13/16" (0.813) spanner so just need to check the OD of the thread.
Just put "nut AF sizes" into your search engine
Edited By JasonB on 27/06/2015 07:31:56
Michael Gilligan27/06/2015 07:35:21
23121 forum posts
1360 photos
Cap'n,
1956, Yorkshire : The threads will almost certainly be either BSW or BSF
Spanner sizes are the same for each, except that newer BSW nuts are one size smaller than the original ones [and are the same across-flats as the BSF].
Whitworth spanner sizes are not, however, in the normal "AF" series ... so you might want to double-check the fit.
P.S. ... You might find this previous thread of some interest.
Edited By Michael Gilligan on 27/06/2015 07:39:04
Nicholas Farr27/06/2015 20:55:27
3988 forum posts
1799 photos
Hi Capnahab, spanners don't normally fit exactly snug on the size nut they are made for and there is always some amount of slack. The slackness varies from one manufacturer to another and ring spanners very often have a little tad more than open ended ones. A 13/16" AF spanner should fit a 9/16" unified (UNF & UNC) nut/bolt, however it will fit a 1/2" BSW or BSF nut/bolt. On an old spanner, you may well see the spanner marked as 7/16" BSW/1/2"BSF as shown in the photo below.
In this photo is a 1/2" whit bolt with a clearance for a 0.2mm feeler gauge, but in the next photo is the same nut in a 13/16" AF spanner but it will only accommodate a 0.05mm feeler gauge.
So if you can only get a similar feeler gauge or smaller or none at all in with you 13/16" AF spanner, then your nuts are most likely 1/2" BSW or BSF, you will need to find out the diameter of the bolt and the TPI.
It is also possible that your nuts are old enough to be from before Whitworth nuts/bolts were reduced down to the same size as BSF in which case they could be 7/16"BSW.
Regards Nick.
Edited By Nicholas Farr on 27/06/2015 21:00:36
duncan webster27/06/2015 21:05:06
5307 forum posts
83 photos
I thought the reduction is size was a wartime economy, so 1956 should be post that
Nicholas Farr27/06/2015 21:16:14
3988 forum posts
1799 photos
Hi Duncan, yes 1956 was past the time of reduction, but they did seem to linger in stores stocks for quite some time. In a previous employment the stores still had a verity of the old ones as late as the 1980's.
Regards Nick.
Bazyle27/06/2015 23:09:26
6956 forum posts
229 photos
Are you making the entire top slide from scratch? If you have a screw this nut is going onto why don't you measure it and if BSW or BSF see if you can get nuts at all before you worry what size spanner fits.
Nicholas Farr27/06/2015 23:47:24
3988 forum posts
1799 photos
Hi Bazyle, you can get BSW & BSF at most industrial suppliers that sell nuts and bolts and failing them they are available at **LINK** although they are zinc plated. Just scroll down to Nuts and then choose Hex Full >
Regards Nick.
capnahab28/06/2015 10:12:08
194 forum posts
17 photos
Thanks , I am renovating this DSG lathe. I cannot get the nuts out (which are rounded) without disassembling the topside (- my next problem) , Any tips welcome. I have been avoiding tackling the brass/bronze nuts holding the topside screw captive as there is so little room to get a spanner at them. Its the reassembly I am fearful of. I do need to do it tho because there is 58 years worth of castor oil crud in there which is now staining everything and making the topside very stiff to use.
Neil Wyatt28/06/2015 10:48:25
19226 forum posts
749 photos
86 articles
I bet it has the consistency of tar by now - but smells nice
Capstan Speaking28/06/2015 11:24:19
177 forum posts
14 photos
Capn'
When you can't get a purchase on something threaded that is tight, one technique is to use a centre punch.
First pick a point as close to the outside edge as possible. On these nuts use one of the hex corners. Then tap the punch in a couple of times to get a bite. Now, in the direction of unscrewing, use the punch to drive it around.
Pick your angle to keep it digging in but also to push sideways. As it unscrews follow it round with the punch. You can take a fresh bite if necessary.
Given the circumstances of the clamp nuts I'm pretty sure it will work.
Bazyle28/06/2015 11:42:58
6956 forum posts
229 photos
Interesting to see the details of a big top end lathe. For the rounded nut laboriously file new flats each side using old credit card to protect the cast iron.
Thanks for the link Nick, yes I do realise that imperial kit is available but look at the price, and those guys don't list BSW. Intersting in that yesterday I was derusting some some 1/4 BSF bolts thinking it was hadly worth the bother but I see they are 86p each and the nylocks 46p. So Ican see why you don't want to buy both BSF and BSW selection to cover both angles. You could check another similar bolt that you can extract to see if they considered it acceptable to tap cast iron with a fine thread.
capnahab28/06/2015 16:59:08
194 forum posts
17 photos
Bazyle, thank you. I think if DSG wanted to put a fine thread on their metal , developed in house , they can do anything they want. Reminds me of the time Beavis and Butthead , famously disrespectful of anyone and anything said that Lemmy could do anything he wants. The video has been removed but this is just as good. If Lemmy had a lathe it would be a DSG, possibly a Holbrook.
ps don't think its fine from what I can see of the bolt.
Edited By capnahab on 28/06/2015 17:06:58
Edited By capnahab on 28/06/2015 17:19:41
Michael Gilligan28/06/2015 18:48:25
23121 forum posts
1360 photos
Posted by capnahab on 28/06/2015 16:59:08:
I think if DSG wanted to put a fine thread on their metal , developed in house , they can do anything they wantt
Quite so ... and here's another thought: I have not had the pleasure of inspecting a DSG lathe, but it looks to me like those nuts must be on Tee-Bolts working in a circular track [square section or dovetailed].
From what I can see in your picture, my guess is that they are 3/8" BSF. or maybe 'later-version' 3/8" BSW ... , either of which should be reasonably easy to find.
If all else fails, you could probably drill into a face of the nut, and then split it with a sharp Cold-Chisel ... should unscrew very easily then.
capnahab28/06/2015 20:18:54
194 forum posts
17 photos
img_6311.jpgI have resorted to taking the topside off. Much old castor oil everywhere, - before and after. At least I can see the thread and have liberated the nuts.
this website thinks any image that is taller than wide must be the wrong way round and rotates it. Neil - any chance of getting some decent software ?. The pics below are rotated.
capnahab28/06/2015 20:21:42
194 forum posts
17 photos
ps , when I was at school anyone who put those round marks near the bottom crosslide allen screw would have been for it...
JasonB28/06/2015 20:29:08
Not much wrong with the software this end
Edited By JasonB on 28/06/2015 20:29:33
Michael Gilligan28/06/2015 20:40:44
23121 forum posts
1360 photos
Good work, Capn'
So ... are they 3/8" BSF, or what ?
Neil Wyatt28/06/2015 21:16:23
19226 forum posts
749 photos
86 articles
Capn' - this usually means you are viewing the images with viewer or website that keeps orientation data in a separate file so you see the image rotated, but the image isn't really changed.
capnahab28/06/2015 23:30:24
194 forum posts
17 photos
OK guys they are 1/2 inch , 12 tpi, so BSW. Have to get all the staining crud out and top half of the topslide off without disturbing the relieving mechanism.
Regarding image rotation , if it's my software in the viewer why is my post rotated and Jason's the right way up in the same window ?.
