terry simpson 1 | 26/06/2015 08:32:44 |
18 forum posts | Finally given up, sick of pouring oil into the lubricator cup to have the lathe swarf tray swimming in oil due to the deterioration of the felt wick feed to the bronze headstock bearing. Unable to find replacement part for the felt pad, what method has been used to make and replace the old pad has been devised over the years by our Myford user friends. Unable to find any topic for the subject on the forum. |
V8Eng | 26/06/2015 08:50:58 |
1826 forum posts 1 photos | Have you looked at the Myford site, certainly listed. Edited By V8Eng on 26/06/2015 08:51:37 |
Mike | 26/06/2015 08:59:44 |
![]() 713 forum posts 6 photos | If you go to **LINK** and enter "lubricating wick" in the search panel it will take you to a page where the components currently available are listed. Pictures are clear, so you should be able to pick the right one. |
Ady1 | 26/06/2015 09:02:55 |
![]() 6137 forum posts 893 photos | I only have small oilers on my Drumond M series and no wicks I use colloidal graphite mixed with my chosen oil and use a small pipet and an old plastic pills container The plastic cup of mixed oil has a small round neodymium magnet in it, to collect any metal dust No problems after 5 years I find that I do my slideways and leadscrews a lot more than my headstock bearings, so a drip into the headstock oilers when I do my slideways has been the habit The plastic pipet allows me to put oil accurately pretty much anywhere on the lathe, anytime I want Edited By Ady1 on 26/06/2015 09:21:36 |
Ady1 | 26/06/2015 09:13:29 |
![]() 6137 forum posts 893 photos | You can buy plastic pipets for buttons nowadays, and you never get oil on your fingers if you use one, even a good oilcan can get a bit oily after a while Item 261904623756 on a well known auction site for example 3ml may be too small, but you can get 5 and 10ml pipettes as well Edited By Ady1 on 26/06/2015 09:28:26 |
Ajohnw | 26/06/2015 09:40:50 |
3631 forum posts 160 photos | I bought these for oiling. I'm also going to try one for applying small quantities of cutting oil to the brush I use on the lathe. A smear of cutting oil can make a big difference. No problem using them to put a few drops of oil even in very small oiler cups. Ebay 131440006606 Anyone know what the small diameter of these wicks are approx and the length? John - |
