richardandtracy | 15/06/2015 14:32:50 | |||||
![]() 943 forum posts 10 photos | I wonder if someone could help me. I use Mach 3 with a Chinese 6040 gantry cnc. One thing I have tried to find is how to set the current tool position as a particular X/Y/Z position. I have tried entering values for the X/Y/Z, and the wretched thing takes off without re-setting the co-ordinates. I can set the X/Y/Z to 0/0/0, but there are occasions when I want to set it to a particular co-ordinate. Can anyone help me? I have looked on the Mach 3 help forum, but suspect it's too simple to have been covered, and as the forum seems as friendly & helpful as it is, I ain't joining to ask a question. One other question: Is there a recognisable & usable help file for Mach 3 anywhere that I could download? My cnc controller PC is not internet enabled, and never will be, so the fact that there is no description in Mach 3 as to what each bit of the program does is ^%&*%&^*"!$! irritating. I would like to look a feature up when I think about it, and not after a 20 minute wait before I can fire up Google on a machine in the house (when I really want to be in the workshop) to start a search. Also, searching a forum for help is a dog's dinner way of getting help compared to a proper help file. Regards, Richard | |||||
David Jupp | 15/06/2015 14:56:49 | |||||
978 forum posts 26 photos | Mach 3 Product Manuals are available for download from **LINK** | |||||
richardandtracy | 15/06/2015 15:08:04 | |||||
![]() 943 forum posts 10 photos | David, Thank you for that. I had missed it completely despite (as I thought) checking through all the artsoft pages. Regards, Richard | |||||
David Jupp | 15/06/2015 15:12:24 | |||||
978 forum posts 26 photos | No problem - I've sometimes failed to see things like that before. Even more annoying when you have found it once, then can't find it again... | |||||
Michael Horner | 15/06/2015 15:32:23 | |||||
229 forum posts 63 photos | Hi Richard Look up the G52 code and see if that is what you want. I think you have done some programing so shouldn't hurt your head too much. Gave me a headache Cheers Michael From wikipedia
richardandtracy | 15/06/2015 16:04:27 | |||||
![]() 943 forum posts 10 photos | Thanks. I'll try that (presumably it's entered as a 'Current Work Offset' on the 'Offsets-Alt-5)' page. I will try & see if I can get it to work. Regards, Richard | |||||
Michael Checkley | 15/06/2015 19:52:52 | |||||
![]() 121 forum posts 66 photos | Do you want to just change the displayed XYZ? If so you can just click on the displayed number to select it and type in any value you like... | |||||
Bowber | 15/06/2015 20:04:26 | |||||
169 forum posts 24 photos | Like Michael said, just click in the box and type the value your wanting displayed, I do this sometime when I do a run from here after I've had a problem and had to reset. Steve | |||||
Phil super7 | 15/06/2015 20:33:26 | |||||
24 forum posts | First you need to home each axis I assume you have home/limit switches, so that mach3 knows its starting point. Then move each axis to where you would like it start from ,at this point zero the axis, when you have done this on all three axis, you can use "GOTOZ" to move to that point from any other position Edited By Phil Morris on 15/06/2015 21:01:21 | |||||
John Haine | 15/06/2015 22:08:51 | |||||
5563 forum posts 322 photos | Richard, it's not entirely clear what you are trying to do. If the tool is stationary at a particular position "x,y,z", do you want to call that position something else like "1,2,3"? If so, then as Michael and others have said, just click the cursor in the appropriate DRO Box and type in the number you want then "return". If this doesn't work there is something wrong. I use this quite a lot at least for tool height setting. Axis homing is optional. All it does is move the control point to an arbitrary position which then the machine uses internally. As far as I can see the only purpose for it is so soft limits have something to work with. In practice one zeroes the tool relative to an origin on the work and Mach then works in machine coordinates. I used to be religious about "homing all" when I started a session but I never bother now though I expect I should. I use a contact probe to set x and y to appropriate edges of the workpiece or a fixture into which it's clamped. This is driven by a set of routines accessed through the edge finder buttons on the referencing tab. When it finds an edge, it uses the probe radius to set x or y to the appropriate value. I set Z by touching the tool on a spring loaded button at a known height above the table. The height routine then moves the tool up by a known amount and sets the Z coordinate to the actual tool height. All of these operations involve manipulating the contents of the DROs. | |||||
John Haine | 16/06/2015 08:11:49 | |||||
5563 forum posts 322 photos | Oops! After homing and then zeroing to a position on the work should say the machine operates in work coordinates... | |||||
richardandtracy | 16/06/2015 08:30:37 | |||||
![]() 943 forum posts 10 photos | Posted by Michael Checkley on 15/06/2015 19:52:52:
Do you want to just change the displayed XYZ? If so you can just click on the displayed number to select it and type in any value you like... Thanks, but occasionally, instead of the number changing, the machine heads off to the current co-ordinate position of the number I've just typed in. I suspect that, being without the manual until yesterday, it's just that I have no idea what most of the functions are, and have been using Mach 3 is its ultimate basic manner. Regards, Richard.
Ady1 | 16/06/2015 08:42:39 | |||||
![]() 6137 forum posts 893 photos | That picture/jpg actually disappears below the advert for me so I have done a drag/copy/paste Temporarily shifts program zero to a new location. It is simply "an offset from an offset", that is, an additional offset added onto the WCS offset. This simplifies programming in some cases. The typical example is moving from part to part in a multipart setup. With G54 active, G52 X140.0 Y170.0 shifts program zero 140 mm over in X and 170 mm over in Y. When the part "over there" is done, G52 X0 Y0 returns program zero to normal G54 (by reducing G52 offset to nothing). The same result can also be achieved (1) using multiple WCS origins, G54/G55/G56/G57/G58/G59; (2) on newer controls, G54.1 P1/P2/P3/etc. (all the way up to P48); or (3) using G10 for programmable data input, in which the program can write new offset values to the offset registers. Which method to use depends on shop-specific applic | |||||
richardandtracy | 16/06/2015 09:31:52 | |||||
![]() 943 forum posts 10 photos | Posted by Phil super7 on 15/06/2015 20:33:26:
First you need to home each axis I assume you have home/limit switches, so that mach3 knows its starting point. Then move each axis to where you would like it start from ,at this point zero the axis, when you have done this on all three axis, you can use "GOTOZ" to move to that point from any other position Edited By Phil Morris on 15/06/2015 21:01:21 The machine does not have limit switches, and neither can the controller cope with them. It is a cheap & cheerful Chinese gantry engraver/very light mill. Which is no problem as I principally want to machine plastics during pen making, though I also need to machine the pen boxes (to match the surface engraving) from walnut. I probably do need to set up software limits in machine co-ords. Regards, Richard | |||||
Bowber | 16/06/2015 09:50:25 | |||||
169 forum posts 24 photos | Posted by John Haine on 15/06/2015 22:08:51:
Richard, it's not entirely clear what you are trying to do. If the tool is stationary at a particular position "x,y,z", do you want to call that position something else like "1,2,3"? If so, then as Michael and others have said, just click the cursor in the appropriate DRO Box and type in the number you want then "return". If this doesn't work there is something wrong. I use this quite a lot at least for tool height setting. Axis homing is optional. All it does is move the control point to an arbitrary position which then the machine uses internally. As far as I can see the only purpose for it is so soft limits have something to work with. In practice one zeroes the tool relative to an origin on the work and Mach then works in machine coordinates. I used to be religious about "homing all" when I started a session but I never bother now though I expect I should. I think there was a discussion once on the Mach forum about this and I "think" the conclusion was you should home occasionally because the difference from home zero to work zero can reach a very high number eventually and this can cause Mach problems. Richard if your machine is heading off to the coordinates you type in the DRO box then Mach not working as expected | |||||
richardandtracy | 16/06/2015 10:53:28 | |||||
![]() 943 forum posts 10 photos | Ahh It's as if, sometimes, the new co-ords are taken as a G0 command. I have been concentrating on reducing electrical noise up until now (as it can cause spurious stepping) and now need to learn the controller in more detail. It is possible the program has glitched due to electrical noise - every now & again the mouse/keyboard have to be unplugged as the spindle variable speed drive causes the computer to fail to respond to USB input. It may be another symptom of something I hope I have now cured. Regards, Richard | |||||
Involute Curve | 16/06/2015 11:37:54 | |||||
![]() 337 forum posts 107 photos | you should check your USB port is not shutting down due to power management this can cause issues. | |||||
richardandtracy | 16/06/2015 12:09:03 | |||||
![]() 943 forum posts 10 photos | The USB shutting down is not a power management issue - I have a specially bought Dell desktop and all power management features are shut off on a clean install of XP Pro. The Mach 3 version I'm using is R3.043.066. I do know the Chinese VFD I'm using is unbelievably electrically noisy. It is impossible to use the radio when the thing is on, and both shielding & distance help with the effect, and (to a limited extent) orientation. Interference with the PC and/or stepper motors only happens on the wind down as the VFD frequency approaches zero and the iron ring noise choke becomes less effective. Regards, Richard
Involute Curve | 16/06/2015 13:21:46 | |||||
![]() 337 forum posts 107 photos | yep that version seems to me to be full of inconsistencies, if I install that on my Mill it becomes very unstable, with the older version I can run 3 mpm cutting figure of eights, and a full cup of coffee doesn't spill, the movement is so smooth, however install the later version and it becomes a different animal, I've spent ages retuning the Servos to no avail, I gave up in the end a reinstalled the earlier version. Shaun Edited to add, I also have a cheapo Huanyang inverter on my lathe, which is next to the miller this doesn't effect the CNC mill either, although I rarely run them both at the same time. Edited By Involute Curve on 16/06/2015 13:25:46 | |||||
richardandtracy | 16/06/2015 14:53:51 | |||||
![]() 943 forum posts 10 photos | OK, I'll try 2.63 (which seems the closest to the one you have). Regards, Richard. |
