Colin LLoyd | 12/06/2015 13:47:39 |
![]() 211 forum posts 18 photos | I refuse to throw away electric motors that still work - but haven't yet put any of them to good use in the workshop - oh except one where I converted a 12v battery drill/driver motor to a dedicated flexible shaft setup for drilling, rotary filing and sanding in difficult places. I have several hover mower motors with belt drive on rigid plates to bearings where the blade is normally held. Has anybody got any good ideas as to how I can put these to use in the workshop. If you lot can't think of practical uses - then no-one can, and I might as well scrap them. |
John Rudd | 12/06/2015 14:21:09 |
1479 forum posts 1 photos | Errmmmm depending on the rating of the motor, you could use one to make a variable speed bench grinder..... A decent speed controller and some wheels, a bit of metal would make a nice vari speed machine, probably more versatile than the fixed speed models..... Assuming of course we are talking brushed motors.... |
Ajohnw | 12/06/2015 17:09:16 |
3631 forum posts 160 photos | I don't know how big these are but lathe tool post grinders don't need a lot of power, neither does tool post mounted milling arrangements either really for key ways and other light jobs. John - |
john carruthers | 12/06/2015 18:10:14 |
![]() 617 forum posts 180 photos | mini wind turbines if they're suitable ? |
john fletcher 1 | 12/06/2015 19:56:27 |
893 forum posts | Before using the motor to power a grinder, ensure that the motor speed and recommended speed of the grinder wheel are compatible. I don't think they are suitable for a wind turbine either, you need to alter the field system for that.Ted |
Rainbows | 12/06/2015 20:08:25 |
658 forum posts 236 photos | If they still work you can get a bit more money selling than scrapping.
You could make a belt grinder: useful for shaping metal.
If you do wood work you could make a disc sander or a wood turning lathe.
