Machining nylon bar stock
Dave Harding 111/06/2015 23:50:56
148 forum posts
4 photos
Iv been trying to reduce 32mm nylon bar stock to 20mm. Its all I have. I have never worked with this material before. The finish is horrible. How do you machine this stuff. Speeds and feeds Iv tried every thing the work piece is awful.
ANDY CAWLEY12/06/2015 01:24:13
190 forum posts
50 photos
Machining PTFE I used high speeds ( 800rpm on 90mm dia) and quite hig feeds ( sorry I don't have numbers) and a very sharp tangential cutting tool in HSS. Nylon could easily be similar.
Thor 🇳🇴12/06/2015 05:34:36
1766 forum posts
46 photos
Hi Dave,
As Andy say, use high speeds and a sharp tool. Here is a link that may be of interest:
*** Link***
Thor
Rik Shaw12/06/2015 07:47:27
1494 forum posts
403 photos
Use a razor sharp knife tool and you should not have any probs.
Rik
Brian Wood12/06/2015 08:34:53
2742 forum posts
39 photos
Hello Dave,
The secret is to use a really heavy feed, the tooling isn't critical, I have machined nylon with tipped tools, brazed carbide and HSS with equally good results.
Reducing 32 mm stock to 20 mm can be done in two passes, a 4mm roughing cut followed with a 2 mm finishing cut. Work speed is about 500-600 rpm and the 'swarf' justs flows over the tool in a satisfying ribbon.
Coolant for deep drilling, where the risk of hole closure around the drill is present seems to favour WD40 or a paraffin based liquid. For drilling keep pulling out the drill to clear the flutes and when it starts to smoke let things cool down a bit..
Trying to shave off the final thou or so doesn't work well as the stuff is fibrous and just tears.
I hope that helps
ANDY CAWLEY12/06/2015 10:25:30
190 forum posts
50 photos
There is a photo on the "What did you do today page of the pile of swarf that landed 4 feet awaysmiley
Edited By ANDY CAWLEY on 12/06/2015 10:27:00
Gary Wooding12/06/2015 14:30:45
1074 forum posts
290 photos
I've done lots of turning and milling of Nylon. With sharp tools it machines very easily and gives a good finish.
Turning produces very long ribbons that get everywhere, so I traverse the workpiece in bursts to break the ribbon before it gets too long and wraps around the chuck. Blunt tools tend to rub and produce sufficient heat to locally melt the Nylon, which results in a very poor finish. This is particularly true when drilling large diameter holes. Be careful when using slitting saws; the saw can easily generate sufficient heat to weld the Nylon to the saw, with obvious results.
Dave Harding 113/06/2015 00:23:17
148 forum posts
4 photos
I give up on it the finish is rubbish no matter what I do. I'm going to buy some 20mm barstock I'm wasting to much time and material trying to get it right.
