12 months after beginning my first model eng. project, I think I can finally begin!
I had to do a lot of learning!
Russ B08/06/2015 14:15:46
635 forum posts
34 photos
Well after a shaky (and tapered) start I'm finally in a position where I've had the time and necessary bits to properly get going on learning to use my lathe.
I began by turning the crankcase for the Boll Aero (yep, I just started with that, bolted the lathe down and started!), using a disposable carbide tool touched up on a fine diamond file, it went well and is probably usable but when finishing the purely cosmetic intermittent cut around the cylinder section I noticed strange patterns regardless of speed or feed. (this was almost a year ago)
Long story short, the lathe was bolted down and levelish but the bearings and slides all needed some attention and tweaking.
After a good strip down and adjust the lathe was running smoother and quieter than ever before, but was sadly also turning a significant taper. I learnt that the tailstock end of the machine would need fine tuning by use of shims under the feet or adjustable raising blocks. In addition my lathe bench (made from an old kitchen worktop) wasn't strong enough and the shimming would simply twist the bench by fractions rather than the lathe.
I got a good old English lathe bench from a Boxford for around £100 and modified it to suit. I made my own adjustable raisers, taller than the typical Myford type which helps me get under the lathe and clean, and also is more comfortable for me - I was now in a position to get the lathe setup properly and turning parallel !!
After levelling and mortaring the bench in place I anchored it left and right to the brick wall parallel to it to absorb any vibration (if any?). I set up the lathe on the risers and began turning a 100mm portion of a piece of 25mm round EN8 held just in the 3 jaw and adjusting the tailstock foot level to suit until I had a parallel section which was smaller if anything (mine was -0.003mm) from headstock to floating end (as I didn't really want it the other way) - this required such fine adjustment of the levelling screw I'm not even sure I was making any adjustment.
I will re check this in a month or 2 but it's good enough for now.
I then went on to setup the tailstock on centre by turning a bar between centres - it was quite far out.
So far, its taken well over a year, gather bits and knowledge but
- I've familiarised myself with the lathe and its operation,
- I've honed my tool grinding/honing skills enough to get usable pieces (eventually!)
- I've adjusted the lathes bearings and slides
- I've set the lathe to turn parallel (and adjusted the bearings and slides again while doing this)
- I've set the tailstock on centre
- I've made LOTS AND LOTS of swarf - its endless.
I think I'm ready to begin.......
I thought I'd start this thread as a build log, and certainly welcome any comments, tips or error spotting.
Thanks for reading,
Russ
Russ B08/06/2015 14:17:30
635 forum posts
34 photos
if you think the picture looks familiar, 9 months ago, I thought I was beginning .......... cheeky
Foolish boy!!
http://www.model-engineer.co.uk/forums/postings.asp?th=99605
Edited By Russ B on 08/06/2015 14:17:49
Ady108/06/2015 14:35:41
6137 forum posts
893 photos
Been about 5 years so far for me and I still feel like I've got nowhere and done nothing significant.
Not much time when you have other commitments 7 days a week and working until 3am just doesn't seem to be possible anymore
Anyhoo, bash on regardless. We will overcome. Forwards to victory. Ne illigitimi carborundum etc
Steven Greenhough08/06/2015 14:38:51
144 forum posts
54 photos
Similar story for me. 12 months and only just starting to see real progress on my project. Haven't really messed with the lathe setup though... maybe it will be a defining factor.
Russ B08/06/2015 14:58:27
635 forum posts
34 photos
Ady1, I know what you mean, I've made quite a few "luxury" purchases angled directly towards this issue, and it has cost me quite a bit of my overdraft, but I thought, enough is enough! Most usefully, a quick change tool post and lots of holders (£200), a power hacksaw (£100 on ebay) , a large vacuum cleaner (£30 B&Q), disposable blue roll (£23 for 12) & 50/50 parafin/HLP32 for cleaning down, a load of old taper shank drills (£40 ish) to quickly get holes near size, a load of old bar stock and scraps (£40) so I hopefully have what I need - just trying to minimise fussing and maximise productivity, I think it's only the way for me, otherwise if I get an hour, or MAKE an hour should I say, it's eaten up by wandering around in the garage faffing at nothing and getting nowhere.
Steven, I knew I had issues when turning a part it was larger at the tailstock end, meaning shafts wouldn't fit in holes, and then would suddenly be to loose by a long way - confirmed by taking a few light passes with a sharp tool on some steel bar - I had a significant taper even on short parts
Now I'm levelled/shimmed if a hole and shaft are very close they seem to go and get VERY stuck, so I have to be careful not force 2 parts together to much - I'm hand finishing with fine abrasive emery if a really close fit is required - I'm not sure if this is normal, I think I've seen/heard of people doing it
Once my new stand and everything has settled in I'll try to readjust the adjustable raisers and lower that -0.003mm taper in 100mm away from the chuck which should hopefully reduce this hole/shaft sticking a little bit.
Edited By Russ B on 08/06/2015 15:00:19
Ajohnw08/06/2015 16:19:10
3631 forum posts
160 photos
When buying a lathe especially a used one it's best to go for those which come with the basic attachments - 3, 4 jaw, face plate and the steadies preferably both but especially the fixed one. A good solid maybe rather old drill chuck is a good idea too.
I'm going to need to produce some very round precise work eventually for a Pultra spindle. One thought has been mostly doing it between centres so I looked around for signs of a between centre test bar. All seem to have morse tapers on the end - not what I want. I came across suggestions for making one. With more detail it sounds feasible. Might be of use to people.
Hold one end of a piece of sliver steel as closely on centre as possible. I'm thinking well sub 1/10 thou, no movement at all on the dti. Same the other end in the fixed steady. Face off, recess and centre drill not using too small a size as it needs to produce a round hole even if the tail stock is marginally off centre - a very small one might bend. I'd also turn the end down for a short distance and chamfer the ends, Reverse and do the same to the other end. The 60 degree part of the centre hole shouldn't be very wide - say 1.5mm or less.
This should finish up with a shorter version of what is used to set up lathes - one problem is that I understand that they may use DTI's with sort of bar like attachment on the end so that the bed error can be dealt with separately. Errors in the bar should be well short of the usual +/-0.0005in error typically quoted for between centre work where large numbers of parts are being made.
One other thing I have found concerning round parallel parts just held in the chuck is the need to make repeated cuts at the same setting due to the work bending and slight play in the bearings. Too much play in the bearings can even cause problems when this done. The drive belt might be positioning the spindle.
There are other fixes to achieve perfection that take the lathe completely out of it. The travelling steady or the type of cutter boxes used on capstan lathes. This is using the same principle as centreless grinding uses - circles and 3 points. Things have to come out round. I expect a comment on that but don't believe the 50p piece argument as massive numbers of things are made this way and come out round to very fine limits.
frank brown08/06/2015 19:39:30
436 forum posts
5 photos
!2 Months, Pah! , I've had mine for about 32 years and have not quite got it fettled.
Frank
Jesse Hancock 108/06/2015 21:11:26
314 forum posts
I can well understand since I have a few bucket loads of tools, an extra Milling machine, Blah, Blah, Blah. Who was that said calculate how long it should take and multiply by two? Make that ten. Some people loose themselves just tuning their machines and never make sod all. Others make models but most (beginners) just make a mess. I know I do.
Russ B08/06/2015 21:27:40
635 forum posts
34 photos
Posted by Jesse Hancock 1 on 08/06/2015 21:11:26:
ive just finished making a fine mess!
The back plate to be specific, it should have had a 0.75 blind hole inside a 0.89 spigot. I bored the hole to 0.890 and only realised after I'd made and turned the whole shebang from one side with the blind bore to exactly 0.550 deep. I'd made a very slightly tapered "thing" to fit in that hole enabling me to machine the other side set everything up, zeroed in the back side facing the chuck and took a cut to mark the flange at 0.150 thick and prepared to start turning down to "what was that diameter...... 0.750..... Hang on.... Oh bugger that's the ID......... Wasted my whole evening,
Well that was a bit disheartening, after faffing about that was a good 3 hours down the pan,
Ten to nine, time to eat/shower/sleep ready for another day at the office!
Ajohnw08/06/2015 21:32:54
3631 forum posts
160 photos
I'm much the same on my Boxford but not so long only around 15 years, so long I am not sure. I don't usually machine for hours on end, just bits and pieces. It took several months to get the slides right, several adjustments. They are still a little tight really but better than having them loose. Bearings adjusted I don't know how many times for the 1st year as they settled down.
Then I decided to strip the entire lathe head. I soon found out why the bearings were tricky. I heard a rumour that Boxford have been known to make the fit on the spindle too tight - very true. I cleaned up all of the old grease and took a few um off the end of the spindle with a lap on a Peatol lathe. That fixed the fit. I then had the bright idea of greasing the spindle to ease fitting - a really bad idea as the grease messes up adjustment and wont go away. I also decided to grease the outer side of the spindle where the back gear runs. Seemed like a good idea as ME10's are a pain to pump oil in to lubricated it. Trouble is that the heat conduction from the spindle is now so good that the bearings no longer warm up and tighten a touch - not sure if that is good or bad yet but I wouldn't mind betting I will have to strip it again, clean up and use oil as before.
One irritation. The lathe has a slight wobble on a large pulley on the counter shaft. Vibrations from this shows a slight few if that um pattern in the finish when I try hard. First attempt to fix - replaced the bearings - no change so then checked that the pulley is square to the shaft - it seems to be. So it seems the casting carrying the bearings is warped. I then tried a lighter pulley - seemed to improve things but while using the lathe the lot came loose - not sure why. I'm currently tidying up to have another go at re assembling that set up. Next step will have to be a reduced diameter on one end of the counter shaft to carry some sort of self aligning bearing set up that I can move about. I reckon the error is ove 1/16in.
Taper last time I measured it with 6in of 1in ms bar sticking out of the chuck without a centre was under 0.001in. Might be less if I had run the tool along several more times. I don't stress the bed to correct error as the stand it's on isn't rigid enough - an old kitchen cupboard and a window sill. I did the same as I have done with other lathes like this one. Bolt through the tray fixed rigidly with a nut. Another nut to support the lathe each leg carefully adjusted to support it evenly. Then a nut on top to hold it down but I leave these finger tight..
john
Russ B09/06/2015 15:15:29
635 forum posts
34 photos
A little progress from Sunday evening.
