mick | 27/04/2015 17:24:36 |
421 forum posts 49 photos | Does anyone know where I can get hold of a couple of 404 Woodruff keys |
Tony Pratt 1 | 27/04/2015 17:41:14 |
2319 forum posts 13 photos | tbwfasteners on Ebay. Tony |
roy entwistle | 27/04/2015 18:12:06 |
1716 forum posts | Who on earth buys woodruff keys ? |
Tony Pratt 1 | 27/04/2015 18:21:11 |
2319 forum posts 13 photos | Please don't tell me you make them? |
JasonB | 27/04/2015 18:21:19 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by roy entwistle on 27/04/2015 18:12:06:
Who on earth buys woodruff keys ? The bloke that dropped his and can't find it. |
Oompa Lumpa | 27/04/2015 19:55:29 |
888 forum posts 36 photos | Posted by roy entwistle on 27/04/2015 18:12:06:
Who on earth buys woodruff keys ? There are two clear sides to this comment and I see both quite clearly. If you are retired or at least a model engineer (or any sort of maker/doer) I can see the sense in someone wanting to make one. Even if it is just to experience this. On the other side of the coin, I just would not have the time or inclination, I would pull the box out marked "Woodruff Keys" and select one, modifying it if need be. Anyone trying to earn a crust just doesn't have the time. There is a third option - you are on a breakdown and you can either wait for the shops to open tomorrow or actually get paid for making one, that works for me too. I have done more than my share of all nighters. And a couple of All Weekenders too. graham. |
John Stevenson | 27/04/2015 20:56:28 |
![]() 5068 forum posts 3 photos | Certainly not me.
Anything comes in for repair with a woodruff keyway in goes out with a flat key fitted. Absolutely hate the bloody things. What engineer in his right mind came up with a flawed design that called for an extra deep keyway with sharp corners often going deeper than 1/2 the shaft diameter ??
Seen far, far to many shaft that have peeled open from the bottom of a woodruff keyway. |
Rainbows | 27/04/2015 22:23:07 |
658 forum posts 236 photos | I believe this ebay has 31 of them.
Am I right in saying 404 is 1/8" thick, 1/2" wide and has a height just under 13/64"? |
Steamer1915 | 28/04/2015 07:48:55 |
![]() 171 forum posts 42 photos | Mick, PM sent. Steve. |
mick | 28/04/2015 08:44:47 |
421 forum posts 49 photos | Thanks Steve. All I wanted was a key to replace the one I lost when I removed the spindle on my Myford, not start WW 3!!!! |
Gordon W | 28/04/2015 09:33:29 |
2011 forum posts | At risk of boring everyone- Woodruff keys are not meant for driving loads, they are for location, eg. timing gear. Easiest way to make them is find a bolt of correct dia. and saw a slice off, then file to size. |
