Fusable plug for 5" gauge
andrew winks15/04/2015 07:21:11
117 forum posts
Hi all, anyone with experience making a fusable plug for a copper boiler firebox?
I have a 3/8 ME bush in place in the crown. The plug I believe is drilled and filled with low(ish) temp soft solder but I've also heard of some with a copper rivet sweated in. Advice greatly appreciated.
Dave Bond 115/04/2015 10:21:25
12 forum posts
The copper rivet is I believe designed to blow out leaving a large hole. Just filling with soft solder there is a small risk that the plug re-seals as it cools during pressure release as not all solder would be ejected from the plug.
Steambuff15/04/2015 10:30:32
544 forum posts
8 photos
I don't think the plug would reseal if you filled it with Solder or (usually) White-Metal as it would drop into the fire as it melts and the pressure would tend to blow it into the fire as well.
Neil Wyatt15/04/2015 11:34:18
19226 forum posts
749 photos
86 articles
I think the head of the rivet inside the firebox is stop stop the fire eroding away the plug.
andrew winks15/04/2015 12:39:38
117 forum posts
I agree Dave, once the solder softened and gave way, steam blow would continue until the boiler pressure dropped to atmosphere. Yes, Neil, I would agree the rivet would protect the caulk. My thoughts would be a 1/8" copper rivet sweated in a very sloppy clearance fit in the corresponding hole drilled in the gunmetal plug. Solder, perhaps comsol, gets the highest temp.
JasonB15/04/2015 12:58:53
All the posts I have read in the past on traction engine forums say solder is a NO NO. The Aussie code is tin for presures upto 150psi and pure lead over 150psi.
J
Paul Lousick15/04/2015 13:15:36
2276 forum posts
801 photos
Extract from Australian model code for boilers. (max. pressure for models is 100 psi)
Tin melts at 232 °C (450 °F) ,    Lead melts at 327.5 °C (621.5 °F)
Paul.
Edited By Paul Lousick on 15/04/2015 13:19:45
andrew winks15/04/2015 13:24:00
117 forum posts
Thanks Paul, I do have a copy of the Au code but wondered where tin could actually be sourced. Thats why i was also thinking solder with high tin content.
andrew winks15/04/2015 13:26:48
117 forum posts
My comment earlier about comsol is certainly incorrect, melting temp too high
