Phil Catchesides | 04/04/2015 16:45:44 |
71 forum posts | Got a lubricator, got a chassis - no room ! There is a foul between draw hook shaft, angles for fixing buffer beam and cylinder block. Drawing shows it directly behind hook which is clearly wrong. Where does it go?? Thanks, Phil |
terry callaghan | 04/04/2015 17:19:10 |
237 forum posts 10 photos | hi, the lubricator does seat behind the front buffer. You can see the position on the Pansy I am working on. if you would like me to take some further pictures please ask. michael |
terry callaghan | 04/04/2015 17:20:58 |
237 forum posts 10 photos | <a href="**LINK**" target="_blank"><img src="**LINK**" border="0" alt="pansy photo pansy pic.jpg"/></a> |
Neil Wyatt | 04/04/2015 19:14:34 |
![]() 19226 forum posts 749 photos 86 articles | HOW TO POST IMAGES HOSTED ON PHOTOBUCKET It's top of the list of FAQs Neil Edited By Neil Wyatt on 04/04/2015 19:15:15 |
Phil Catchesides | 04/04/2015 19:18:17 |
71 forum posts | Thanks Terry, is your front hook sprung? My hook-stem with spring, nut and washer extends behind the bumper by about 1" and is about 1/4" diameter so lub. has to miss that. I will try and take a picture tomorrow if I haven't solved it. I know it is a big ask but any chance of a pic. from underneath? Phil |
terry callaghan | 04/04/2015 22:53:08 |
237 forum posts 10 photos | Hi phil, will take pics tomorrow showing all angles.michael |
Anthony Kendall | 05/04/2015 09:45:52 |
178 forum posts | You seem to have decided on a mechanical lubricator. There is another alternative - a displacement lubricator. The picture shows one fitted to a Pansy cab - the output remains to be connected at the top and down through the hole next to the boiler. The expansion tank fits neatly under the floor between the back axle and the brake operating shaft. The cab of 5764 - the lubricator flow sight glasses are on the right (I think!) All included in the best possible taste - it is probably not viable to change course now. Hope it goes OK. Edited By Anthony Kendall on 05/04/2015 09:48:21 Edited By Anthony Kendall on 05/04/2015 10:15:45 |
terry callaghan | 05/04/2015 10:12:38 |
Anthony Kendall | 05/04/2015 10:24:19 |
178 forum posts | Apologies, I should have said hydrostatic, not displacement in the above (I think). Too late to edit. Looks like Terry has the answer for you. Edited By Anthony Kendall on 05/04/2015 10:27:21 Edited By Anthony Kendall on 05/04/2015 10:37:03 |
Phil Catchesides | 05/04/2015 11:28:10 |
71 forum posts | Thanks all for help and pictures. Where I went wrong was building to drawing; the drawing has the drawhook going 1.25" back from front of buffer beam to accommodate a spring and this is impossible at the front with the lubricator. Another big error on the drawings and clearly LBSC never made the loco from his plans ! I will convert the hook to unsprung and then put the lubricator where it is shown on the plans Thanks again, Phil |
terry callaghan | 05/04/2015 13:07:31 |
237 forum posts 10 photos | Phil, if you would like the build notes please let me know your email address and I will send.michael |
Phil Catchesides | 05/04/2015 13:51:32 |
71 forum posts | Thanks Michael I have copies of the articles but they are full of 'I've described this many times before so I won't do it again' for critical operations and lots of text telling me the completely obvious. I had rather hoped that I could build the loco from the drawings but they are really only a reasonable indication of what is required (leaving aside those who think the valve set-up is all wrong). Another example that comes to mind - the motion plate. The cut out for the crosshead pump drive isn't on the frame drawing, it just 'appears' later when you have to strip the chassis down to remove the motion plate to put the cut-out in. Anyway lubricator going in nicely now, the hook is solid to the buffer beam and I am doing the pipe, linkage and filler Good job we didn't make Airbus' like this, Phil |
KWIL | 05/04/2015 16:05:58 |
3681 forum posts 70 photos | Trouble with the "words and music" do not trust everything you read. |
terry callaghan | 05/04/2015 20:18:13 |
237 forum posts 10 photos | Phil, How anyone can build anything from the plans beats me. I think back in the day these builds got done a lot of chaps worked it out together. these days I don't think that there is the level of building and so as a result the level of advice and no how is also dropping. My own Pansy dates to 1964 and Its nice to think that it is still giving joy after 51 years. michael |
