Stainless steel
Brian Rice 131/03/2015 15:29:56
82 forum posts
11 photos
how do I stop stainless steel work hardening when turning in lathe?
martin perman31/03/2015 15:32:49
2095 forum posts
75 photos
I would suggest loads of coolant to take the heat away.
Martin P
duncan webster31/03/2015 15:37:04
5307 forum posts
83 photos
Sharp tool with about 20 degrees top rake, I use High Speed Steel as it is sharper than carbide, reasonable depth of cut, reasonable feed rate. If you try to take a small cut at low feed it won't work. I've had really good results with tangential toolholder. Watch out for the long ribbons of swarf it will cut your hands to shreds.
Brian Wood31/03/2015 15:42:20
2742 forum posts
39 photos
Hello Brian,
Heavy feed, slow speed and use coolant. Much also depends on the grade you are machining, some like 304 are much more amenable and will turn like high carbon steels..
Drilling is best done by 'peck' drilling and with sharp drills, but don't overload it; while swatf comes out of the hole it is OK, the instant it stops withdraw the drill and sharpen it if necessary..
Stainless can be machined with a light cut, in that case increase the feed rate to keep a curl of swarf coming away
Bob Brown 131/03/2015 15:51:52
1022 forum posts
127 photos
Depends on the grade of stainless steel, 304, not too bad, 316 little more difficult, I use insert tooling where ever I can and I'm not convinced by the sharper debate. Drilling and tapping can be problematic and you need the correct tap or die for stainless not some cheap item.
Bob
Oompa Lumpa31/03/2015 17:05:25
888 forum posts
36 photos
Posted by duncan webster on 31/03/2015 15:37:04:
and and spells will go septic.
graham.
(Spell: sliver of swarf in the flesh. Not the type my missus usually conjurs up!)
Mark P.31/03/2015 17:15:24
634 forum posts
9 photos
Never had any problems in machining stainless. Have used carbide and HSS on both 316 and 304, both worked dry.
Mark P.
Brian Rice 131/03/2015 19:06:58
82 forum posts
11 photos
Thank you people
KWIL31/03/2015 19:22:35
3681 forum posts
70 photos
I have used the polished high rake carbide inserts designed for aluminium (CCGT06**** ) very successfully on stainless.
