Matthew Worthington | 23/01/2015 19:13:03 |
2 forum posts | Hi all, I'm new to this and would appreciate some help on how to connect a battery on a 5" gauge locomotive. The photo (see link) shows the connection to the motor/controller on the left and the battery (and its terminals) on the right. Can anyone please advise what type of connection/wire I need for this? Many thanks in advance **LINK** - link to photo. Matt
Michael Gilligan | 23/01/2015 20:43:31 |
![]() 23121 forum posts 1360 photos | Welcome, Matthew Those connectors were originally known as 'Lucar' [Trade Name] but are more commonly just Spade Terminals. ... Any automotive parts supplier should have them in stock. MichaelG. . http://www.google.co.uk/search?q=lucar+connectors Edited By Michael Gilligan on 23/01/2015 20:45:51 |
Johnboy25 | 23/01/2015 21:14:06 |
![]() 260 forum posts 3 photos | Matthew... i belive the connectors are Anderson type connector. Try **LINK** If do a search on eBay for Anderson connectors I think you will find what you want. The battery connections are as Michael has indicated. The other name for them are Spade connectors or Fast on. John |
Bob Brown 1 | 23/01/2015 21:59:31 |
![]() 1022 forum posts 127 photos | As a point of interest what size is your battery and motor/s, I ask as my electric shunter runs a pair of 38amp hour batteries with bolt on connectors supplying 3 x 150 watt motors. I worked on the current the motors were likely to pull say 12 amps ish so the batteries should give a two/three hours of running or may be a bit more with regen braking. I would use normal spade connectors to connect that battery and fit a isolating switch so the batteries can be isolated easily should a problem arise. Bob |
Michael Gilligan | 23/01/2015 22:05:19 |
![]() 23121 forum posts 1360 photos | Posted by Johnboy25 on 23/01/2015 21:14:06:
Matthew... i belive the connectors are Anderson type connector. Try **LINK** . Thanks for the extra info., John I was, of course, only referring to the battery connection. MichaelG. |
Matthew Worthington | 30/01/2015 08:09:03 |
2 forum posts | Many thanks for your help folks ![]() |
MichaelR | 30/01/2015 08:55:49 |
![]() 528 forum posts 79 photos | Look like Power Pole connectors see Here |
