Carl Wilson 4 | 12/12/2014 14:21:44 |
![]() 670 forum posts 53 photos | I am looking at having to form two bends in a number of lengths of stainless tube, 10mm dia by 2mm wall. One or two is fine and easy using a pipe bender, but I have to produce 10+ all exactly the same. Any ideas on how I could do this? Some sort of jig? Carl. |
Ian P | 12/12/2014 15:59:11 |
![]() 2747 forum posts 123 photos | Not difficult to do, but without knowing what bender you are using, what angle the bend (or bends) are to be, how far the bends are from each other (and whether they are in the same plane it not possible to say how to do it. How much 'precision' does your application need? If it was something simple like a 90 degree bend just creating an 'L' shape then put the bend anywhere and trim the two legs to length. Ian P |
Speedy Builder5 | 12/12/2014 16:48:51 |
2878 forum posts 248 photos | You make the first bend and then place this against some form of a STOP before you make the second bend. If the second bend is not in the same plane as the first, then you may have to make a jig to hold the tube. You can't rely on pencil marks in my experience.
Carl Wilson 4 | 12/12/2014 18:09:43 |
![]() 670 forum posts 53 photos | Difficult to say but I think that the bends will need to be within 0.5 - 1 degree of each other. Both bends in the same plane. One of 30 degrees and then 35-40mm along second bend in opposite direction to the first, 15 degrees. |
Ian P | 12/12/2014 18:26:37 |
![]() 2747 forum posts 123 photos | Carl What type of bender are you using? Ian P |
Carl Wilson 4 | 12/12/2014 18:58:53 |
![]() 670 forum posts 53 photos | It is a Ridgid 400 series level instrument tube bender. Fairly bog standard tool in hydraulics work. |
Carl Wilson 4 | 12/12/2014 19:12:13 |
![]() 670 forum posts 53 photos | What I've been thinking is to set the bender up on the mill table, then have a series of stops to locate the length of tube. Further stops to indicate when the bends are complete. |
Michael Gilligan | 12/12/2014 19:54:13 |
![]() 23121 forum posts 1360 photos | Carl, I confess that I have no experience to offer ... but the question is interesting; so I went digging, and found this video which might help. MichaelG. |
Carl Wilson 4 | 12/12/2014 21:41:22 |
![]() 670 forum posts 53 photos | Hello Michael, Thank you for researching on my behalf. I'm familiar with laying out and bending tube as shown in this video. What I've never done (it has just never occurred in my experience before) is to produce a series of tubes that have to all be ostensibly exactly the same. I do not know and indeed have never had cause to wonder exactly how repeatable bending tube is using the time honoured method. I guess it is only as repeatable as my measuring...but there are other factors to consider here. I'm hoping to come up with a simple way to ensure the bends all turn out the same within the limits of measurement. I thought it worth posting here as there is such a wealth of experience that I thought someone might provide me with food for thought, if nothing else. I think the next edition of the SMEE journal is going to have something on pipe bending in it, hopefully I'll have got there before that comes out.
Ian P | 12/12/2014 21:52:34 |
![]() 2747 forum posts 123 photos | Posted by Carl Wilson 4 on 12/12/2014 18:58:53:
It is a Ridgid 400 series level instrument tube bender. Fairly bog standard tool in hydraulics work. I've done thousands of bends in stainless tube (Mostly 1/4" to 1/2" Can you cheat by mounting the fitting and whatever it is going into, 'after' you have bent the tube? Actually I think you might struggle with that bender on 2mm wall tube although if its within Ridgid's rating it must be doable. Ian P
Carl Wilson 4 | 12/12/2014 22:07:14 |
![]() 670 forum posts 53 photos | Hello Ian, Thanks for your post. Like you I've also done a lot of tube bending in 1/4, 3/8 and 1/2 stainless. I usually put one half of the bender in the vice too, for anything over 1/4. I actually think my bender will struggle with the 2mm wall too, but we shall see. Fortunately there will not be any fittings on the end of these tubes, they are going to be welded or brazed up into a sort of heat exchanger. |
Carl Wilson 4 | 13/12/2014 15:56:17 |
![]() 670 forum posts 53 photos | Well, the pipe bender was easily able to bend the 10x2mm tube. Here is a rough example of what I'm going to do. Only another 30 or so to go... |
Ian P | 13/12/2014 16:18:23 |
![]() 2747 forum posts 123 photos | Carl I presume that the most critical/precision aspect of the part that you have to get right is the is the angle between the entry and exit straight sections? with the centre section length and its two angles only having to be visually similar. I have not handled that particular bender but it looks to be robust and well engineered and (in your hands) produces a nice result. Ian P |
Circlip | 13/12/2014 17:51:18 |
1723 forum posts | There must be some "wiggle" room on the final assembly to ensure the tube ends are in the correct position to each other for welding / brazing to the component(s) it attaches so it may be that the bend centres to each other are important and that in one plane, the pipe is flat (You already told us that) Instead of allowing the bender to "Float" it is after all a "Site" type bender (Two handles), fasten the side with the circular former down onto some for of fixed plate (Mill table is brutal to the mill) and after effecting first bend, turn pipe end for end to a fixed stop and clamp pipe to stop lateral rotation after ensuring the bend is flat and bend the second angle. DON'T try to bend it in your hand, fixing the bender down is the clue.
Bet you only manage to waste ONE as a pattern. Don't get complacent when you're shelling them like peas.
Regards Ian..
EDIT. Forgot to mention, However many you have to bend, put one bend in the whole batch FIRST, then go for the second one rather than complete each one individually (Sorry if it's sucking eggs) Edited By Circlip on 13/12/2014 18:01:16 |
Carl Wilson 4 | 13/12/2014 22:43:32 |
![]() 670 forum posts 53 photos | Thanks Ian and Circlip for taking the time out to post. As I mentioned I always clamp one side of the tube bender in the vice. I can manage three shredded wheat, but I can't bend 10x2mm 316 tube freehand without a series of jerky movements, which are not conducive to neat, repeatable work! A good idea to do the first bend in the whole batch, then the second. Mill table would indeed be brutal; I have a table that I can mount stops etc on that I usually use for TIG welding. Thanks again, Carl. |
jason udall | 14/12/2014 10:37:19 |
2032 forum posts 41 photos | Pardon me for stating the obvious. Unless the stock is expensive... Since the part between the bends is the critical length.. With bender bolted down to act on say horizontal plan .add board to behind and near said plane...add such blocks as to provide stops...for length and angle Do first bend...to required parts..plus a few... Add/ remove stops for next bend..... Do second bend... Trim in and out lengths as required.... The latter allows extra length for ease of stops etc. .make from over long if needed to get stop out of swing area... Bend one end |
Carl Wilson 4 | 14/12/2014 11:27:21 |
![]() 670 forum posts 53 photos | Thanks Jason for taking the time out to post. I don't recall stating that the part between the bends was the critical length. What is obvious to one may not be to others. So always worth stating. My current thinking follows yours closely, to use extra length as required for ease of use of stops etc. Thanks again for the interest. Carl.
Carl Wilson 4 | 15/12/2014 10:25:39 |
![]() 670 forum posts 53 photos | And the important aspects are the similarity of the two angles and the distance between them. |
