Brian Abbott | 21/11/2014 13:25:52 |
![]() 523 forum posts 95 photos | Hello. A while ago i read about two ex Myford lads who setup on their own, Has anyone used them recently ? are they still working. Thanks in advance
Geoffrey Mowatt | 21/11/2014 13:39:32 |
9 forum posts | Hello Brian, I just sent off my ML7R headstock and spindle to Darren Boden and had it back in 3 days with new angular contact bearings and a scraped in cone bearing - top class service. I went for posting the headstock as I'm over 3 hours away from Darren who's based in Nottingham. Everything you read about him is top class and my experience is likewise. All the best, Geoff |
Brian Abbott | 21/11/2014 15:09:52 |
![]() 523 forum posts 95 photos | Thanks for the info Geoff..i will forward an e:mail to him.. I have for a while had an annoying knock on my Super 7, cannot make out exactly where its from. so rather than mess with what i don't understand, get an expert to take a look, and possibly service the machine at the same time..
geoff | 21/11/2014 16:30:42 |
29 forum posts | yes Darren is still servicing as far as I know I was in contact with him only a few weeks ago |
Graham Williams 5 | 21/11/2014 17:51:03 |
![]() 98 forum posts 9 photos | Darren and Pete serviced my ML7 beginning of October, nice job running really well. Weekend service only I think and date to service depends on Nottingham Forest home fixtures. |
Brian Abbott | 21/11/2014 18:15:09 |
![]() 523 forum posts 95 photos | Thanks all, Have sent an e:mail to the address given so fingers crossed I get a reply. |
Brian Wood | 24/11/2014 10:54:02 |
2742 forum posts 39 photos | Hello Brian Just a thought but the knock you describe might just be coming from the semi circular bull wheel swing-over lever for backgear working. Perhap worth checking before you go further. Regards Brian |
Brian Abbott | 24/11/2014 23:54:16 |
![]() 523 forum posts 95 photos | Hello, thanks Brian, that's a very good point, it is literally tick, tick, tick, I have had no reply from the email I sent to Darren, so maybe a job to do during the Xmas break.
Edited By Brian Abbott on 24/11/2014 23:54:53 |
Brian Wood | 25/11/2014 11:28:46 |
2742 forum posts 39 photos | Hello again Brian, My 4 step gear cluster that the swing over lever engages into has perhaps 1 mm or so of end float on the spindle and that too has the potential to rattle in the bullwheel pocket made to receive it. I only really gave you half the story, but of the two the semi-circular catch will be the one that variations in cutting loads will have the greatest audible effect upon. Regards Brian |
Chris Trice | 25/11/2014 13:26:08 |
![]() 1376 forum posts 10 photos | I agree with Brian. It's almost certainly the little backgear bull wheel locking lever. If you look at the end of it, you're likely to see evidence of the end of it contacting something and a corresponding silver metal mark in the head casting at the point of contact. Very easy to check by either engaging back gear or using a bit if tape to hold the lever further in place. If you're not too purist about it. You could file a little extra clearance on the end of the lever to stop the ticking. |
Brian Abbott | 25/11/2014 22:51:17 |
![]() 523 forum posts 95 photos | Hello, really not sure. Tried the screw driver against the ear tonight and seems to be coming from the clutch area.. could be the thrust bearing maybe, not a problem just an annoyance. |
WALLACE | 26/11/2014 09:32:43 |
304 forum posts 17 photos | With all due care taken over safety etc, a long screwdriver with the handle up against your ear and the pointy end on various suspect bits of the lathe should help pin it down to a specific area or even bearing. Safer - if costlier - alternative is a 'mechanic's stethoscope' .. ebay probably the cheapest source. W. |
Chris Trice | 26/11/2014 13:20:21 |
![]() 1376 forum posts 10 photos | Does it go away if you engage the backgears? Is it related to spindle speed or motor speed? Both are easy to check. |
Brian Abbott | 30/11/2014 22:12:26 |
![]() 523 forum posts 95 photos | Thanks chaps for taking the time to reply, sorry for the delayed response. I have confused myself with this, not sure now if it's a knock, a rattle or what, so have taken the decisive decision to turn the radio up..until I have time to investigate it properly, providing it doesn't get worse , I think I will live with it. |
