Nick_G | 25/10/2014 08:58:10 |
![]() 1808 forum posts 744 photos | . What diameter, thickness and tooth count would people recommend for a slitting saw for slicing bearings and eccentric straps as found on model sized steam engines.
Cheers, Nick |
JasonB | 25/10/2014 09:36:09 |
![]() 25215 forum posts 3105 photos 1 articles | 3", 1/32" not too critical tooth count. run them slowly |
Russell Eberhardt | 25/10/2014 11:27:38 |
![]() 2785 forum posts 87 photos | Posted by JasonB on 25/10/2014 09:36:09:
3", 1/32" not too critical tooth count. run them slowly .. about 80 rpm for gunmetal. Russell. |
Andrew Johnston | 25/10/2014 11:34:16 |
![]() 7061 forum posts 719 photos | And make sure you use a coarse tooth slitting saw. The fine pitch saws are really only suitable for slotting screw heads and the like. If you use them to take a decent cut the chances are that the swarf will choke the gullet and cause a jam. Andrew |
Nick_G | 25/10/2014 12:03:54 |
![]() 1808 forum posts 744 photos | . Cheers guy's
Nick |
Howard Lewis | 25/10/2014 12:46:12 |
7227 forum posts 21 photos | Whatever you use, DO NOT use a key to the arbor. If it jams, then you will definitely need a new saw! And if it shatters, the debris might hit you. Mostly, I use a 1/16 saw for this sort of work. Keep the feed slow; work on the basis of 0.001"/tooth. Good Luck! Howard |
Andrew Johnston | 25/10/2014 13:38:16 |
![]() 7061 forum posts 719 photos | Posted by Howard Lewis on 25/10/2014 12:46:12:
Whatever you use, DO NOT use a key to the arbor. It's a bit like parting off using power feed; there's them that do, and them that don't, and never the twain shall meet. Andrew |
