Regulator Valve materials
Manofkent12/10/2014 12:48:04
145 forum posts
29 photos
Hi
I am just starting the boiler fittings for my 3 1/2" gauge pacific loco.
I have a lot of aluminium and a little brass / bronze.
Having short arms and deep pockets (!) I wondered if I could use the Aluminium to make the regulator valve which sits in the boiler. There are no brazed parts on this - I am using a Southern Disc type design.
I expect there is a compelling reason why this is a bad idea - can anyone enlighten me please?
Many thanks
Bob Brown 112/10/2014 13:15:38
1022 forum posts
127 photos
I doubt mixing aluminium with a copper boiler is a good idea due to the risk of Galvanic corrosion, aluminium and stainless is not a good idea unless you can isolate the two.
Bob
Jeff Dayman12/10/2014 14:26:38
2356 forum posts
47 photos
Aluminum and hot water/steam do not mix. Rapid corrosion can result, especially in contact with other metals as Bob mentioned. It gets even worse if there is any detergent involved (not likely in steam models, but I have seen some awful results in instrument washing machines and sterilizers in industry)
Bronze is the best choice for boiler fittings. Some people say brass is also OK if exposed to steam only, not used under the water level.
JD
Manofkent12/10/2014 16:37:11
145 forum posts
29 photos
Thanks guys. You have saved me a lot of hassle in the future. I will be hunting for a slab of bronze at the midlands exhibition on Thursday.
Ian S C13/10/2014 12:07:01
7468 forum posts
230 photos
John,if you have a multi meter, try putting a bit of copper and aluminium in some hot water, select a low range on the meter and put one probe on each bit and see the voltage, probably about 0.5V
Ian S C
Neil Wyatt13/10/2014 19:44:38
19226 forum posts
749 photos
86 articles
I've stopped buying aluminium cookware because of the way it looks when it comes out of the dishwasher, let alone the health risk of acidic food reacting with it.
