ruston proctor
plumbing
derek blake11/10/2014 08:43:20
586 forum posts
151 photos
Hi everyone.
I'm building a 2inch scale ruston proctor traction engine, drawings are good except for the plumbing arrangement.
I'd like to understand this better, and possibly do away with the water tanks either side of the boiler, has anyone done this or have any info on the book that came with this kit in 1987.
I'm still cleaning every part of the engine, so I'm in no rush yet.
Can I plumb in a simple hand water pump to keep the pipework simple for now?
Thanks
JasonB11/10/2014 09:08:28
Can you post some pictures as this model does not usually have a belly tank. Is it actually from a kit or built to Hainings design which started publication in 1987?
Talk to your boiler inspector as its more than likely they will require two means of filling the boiler, this is usually by pump off the crankshaft and injector though a hand pump may be possible to replace the injector.
J
derek blake11/10/2014 09:16:06
586 forum posts
151 photos
I will post some pictures, once back from Lyme regis.
Thanks very much
Paul Lousick11/10/2014 10:47:11
2276 forum posts
801 photos
Hi Derek,
Which Ruston Proctor are you building ?
I am building a 6" Ruston Proctor SD which has a water tank in the tender. Some engines also had auxiliary tanks on either side of the boiler. It should not matter where you get your water from but should have 2 independent methods of getting water into the boiler. (injectors, mechanical pump, hand pump, etc)
Paul.
derek blake11/10/2014 16:06:55
586 forum posts
151 photos
Thanks Paul.
I'm building a 2 inch scale version which shows two water tanks either side of the boiler, I'm looking at using just the tank in the tender and doing away with these tanks the main reason is to keep the plumbing simple at first as this is my first engine, I'm not exactly sure how all the piping is done from the drawings view, I wondered if there was a build book with this engine in the past, the drawings say 1987.
Derek
JasonB11/10/2014 16:13:57
Assuming it is Hainings SD rather than Linconshire Lad then there was no book as such but the series of build articles in ME starting April 1987 would be as good as.
Gray6211/10/2014 16:21:14
1058 forum posts
16 photos
Hi Derek,
I have the ME magazines with the John Haining build series, see PM
Graeme
Gray6211/10/2014 20:40:53
1058 forum posts
16 photos
The additional tanks on a Ruston Proctor SD are aranged either side of the boiler in this fashion.
Paul Lousick11/10/2014 22:23:59
2276 forum posts
801 photos
Piping layout for 6" RP SD.
Note that this has a steam operated pump and uses lifting type injectors. I have made the pump according to LSM drawings but am not sure if it will work and I am not going to use positive feed type injectors instead of the lifting type,
Paul
derek blake12/10/2014 08:17:59
586 forum posts
151 photos
Thanks Paul.
I will come back to the plumbing once I have restored the rest of the engine, I will post some pictures to ask what goes where piping wide.
Thanks
derek blake14/10/2014 15:17:24
586 forum posts
151 photos
really struggling understanding the plumbing on the 2 inch ruston..i am new to traction engines so im sure i will get it soon.
its the fact there are different size fitting, but they say to use the same size pipe work thats confusing me.
it says to use 5/32 size pipe on ALL fittings, but i have water lifter bushing with a 5/16x32tpi fitting..do i use the 5/32 pipe still and order a fitting with a 5/16x32 thread and a 5/32 size nipple and union fitting?
I wasnt sure if the water lifter pipe should be of a bigger size..dscf1305.jpg
JasonB14/10/2014 15:54:25
To me it says 5/32" or 3/16" pipe.
Its quite usual to have say 3/16 water feed to water pump with a 5/32 from that to the clack or back into the tender via the bypass. Being anything after the pump is being pushed it does not need such a large dia.
Water lifter steam feed could be 1/8" or 5/32" you are unlikely to use it anyway unless you have a liking for filling the engine from puddles. I would use a standard 5/16 x 32 nut and make a nipple with a smaller hole to take the smaller pipe or just solder on a sleeve to step it upto a larger nipple.
Injector I'd say 5/32" steam feed to it then 3/16" for water feed to it and the same from injector to clack
If its just gravity from the pannier tanks to teh tender than 3/16"
derek blake14/10/2014 16:02:56
586 forum posts
151 photos
Thanks very much, its starting to make abit more sense now
derek blake14/10/2014 16:14:45
586 forum posts
151 photos
so what you are saying is that its better to use the larger pipe 3/16" on the injector side and into the check valve on the right hand side of the boiler, but with the left hand side use the 5/32" from the pump into that check valve?
derek blake14/10/2014 16:22:23
586 forum posts
151 photos
on the drawings it shows two water level glass's one either side from the steam manifold down to the bottom of the boiler, do any pipe fittings go to the bottom of these water levels? do i need to attach a pipe to each one to drain the boiler say?
Thanks for your patience
JasonB14/10/2014 16:28:18
The water gauges usually don't go anywhere near the bottom of the boiler, they only need go just below the top of teh firebox crown which is where the bush(S) should be located on the back of the boiler. Its usual to run a small pipe , 1/8" would do from the cock on the watergauge down to teh bottom of the engine so that when you blow steam/water through the glass to clear it that goes out to waste between the tender and back of the boiler. Can you post a picture of this drawing, I don't think two gauges are really needed on a small engine and not all large ones had two.
EDIT Looks like the full size did have two glasses, this is the layout on a 4" engine, you can see the two small pipes to waste
Edited By JasonB on 14/10/2014 16:32:24
Edited By JasonB on 14/10/2014 16:32:44
derek blake14/10/2014 16:34:26
586 forum posts
151 photos
here you can see the manifold holes on the front to take the top of the water level and the two brass fittings lower down to take the bottom of the levelsdscf1299.jpg
Nigel Bennett14/10/2014 16:36:03
500 forum posts
31 photos
It's usual to have some fairly small pipes leading from the bottom of each gauge glass to "blow through" the glass to clear scum or debris, and to check that the water level restores to its original position. There's usually a blowdown valve mounted low down on the firebox for the purpose of draining the boiler. Having it low down enables all the accumulated pooh to be blown away with the water/steam when the boiler is drained at the end of a run.
derek blake14/10/2014 16:50:17
586 forum posts
151 photos
Ah i see, thank you...i'm starting to learn for sure
derek blake14/10/2014 17:14:04
586 forum posts
151 photos
on the above piping diagram, you will see the steam to water lifter pipe and the steam to injector pipe..
both with a globe valve fitted? i want to make sure i order the correct fittings..Thanks alot
