Prusa i3 Build
Russell Eberhardt28/06/2017 11:22:29
2785 forum posts
87 photos
Posted by Paul Lousick on 26/06/2017 07:15:51:
Can the Prusa use wax fillament instead of plastic? If so a good way to make lost wax castings in metal.
Paul
Lot's of videos out there of people using lost PLA instead of lost wax. Seems to work OK.
Russell
Nick Hulme30/06/2017 11:12:08
750 forum posts
37 photos
Posted by Russell Eberhardt on 28/06/2017 11:22:29:
Paul
Russell
PLA can have burnout problems with fine detail, Moldlay and Machinable Wax filaments are supposed to melt and pour out and then burn out clean, machinable wax actually post the result of a burnout test, the manufacturers of Moldlay don't seem to be aware of the basics of the lost wax process but users who are seem to get reasonable results,
- Nick
Neil Wyatt02/07/2017 16:26:48
19226 forum posts
749 photos
86 articles
I found a new way to waste filament... start a print but forget to put the glass sheet back on the bed after cleaning it...
blush
Nick Hulme10/07/2017 13:38:48
750 forum posts
37 photos
Posted by Neil Wyatt on 02/07/2017 16:26:48:
blush
:D
Neil,
I wanted to print some parts which were problematic from a support point of view with the version of Cura shipped with the machine and spent the time to get my head (part-way) around the latest version of Cura, the addition of Roof and Column support options is a big step forward, speed control for each feature of a layer is also available, plus much I haven't read about yet!
- Nick
Neil Wyatt10/07/2017 20:26:10
19226 forum posts
749 photos
86 articles
Must take a look!
Nick Hulme21/07/2017 16:20:38
750 forum posts
37 photos
ABS seems to work OK with Brim adhesion
Paul Lousick29/07/2017 09:30:43
2276 forum posts
801 photos
Advice needed.
A 3D printer is one of the items on my bucket list and prices are falling, making them more affordable.
Recently saw an add for a Prusa i3 Pro B support 5 filament MK8 extruder for A$219.
Is this the latest model? Should I get upgrades any of the parts ?
Paul
Nick Hulme03/08/2017 22:14:25
750 forum posts
37 photos
The i3 is the current Prusa model so that clone is a clone of the latest model, I assume that's what you were asking?
Paul Lousick03/08/2017 23:32:18
2276 forum posts
801 photos
Hi Nick,
I have just placed an order for a Prusa I3 Pro X Print 6 filament printer with auto bed level sensor. More expensive than the standard I3. (Hope that I have made the right choice). Should arrive in a couple of weeks.
Paul.
Russell Eberhardt04/08/2017 07:55:49
2785 forum posts
87 photos
Paul,
That's an updated version of the one I built at the end of last year. See **LINK**
They might have corrected some of the faults I found now.
Russell
Nick Hulme05/08/2017 18:58:06
750 forum posts
37 photos
I've just fitted a Mk3 Aluminium heated bed to my Factory 3D printer along with a DC-DC SSR and a separate 24v 15A PSU.
The bed now heats up as fast as the hot end for PLA and very close for ABS and Nylon, Happy Days!
- Nick
Neil Wyatt06/08/2017 12:41:30
19226 forum posts
749 photos
86 articles
Posted by Nick Hulme on 05/08/2017 18:58:06:
- Nick
I found that a 12mm aluminium silicate blanket under the bed had the same effect,.
Nick Hulme06/08/2017 14:36:13
750 forum posts
37 photos
Posted by Neil Wyatt on 06/08/2017 12:41:30:
- Nick
Neil,
That is impressive, I'll have to get me some of that blanket! There must be variation in the Mk1 beds as mine struggled to reach 100C for ABS on the standard 12V PSU even after adding some insulation under it.
- Nick
Paul Lousick07/08/2017 10:13:27
2276 forum posts
801 photos
New toy has just arrived. Now to check that all parts are up to spec before I start the assembly. Never enough time in a day though. Neil, where did you get the AS blanket ?
Paul.
